Kingston SKC600/512 S4800105 SM2259H AC No correct loader
Posted: 03.01.25, 09:06
by gameboybin
Exact same problem like in Lasek post. Still no correct loader for this SSD. I have tried every single one of them loaders. None of them Recognized the SSD as a 2x256GB chip SSD
Model : SM2259AC-80-10000001
Serial : (03)5526888-20080228
Firmware : 20141211
Capacity : 1 GB (2 096 640)
Selected family......................... : Silicon Power Slim S55 (SM2259XT)
Controller.............................. : SM2259XT
SSD status:
Firmware mode........................... : ROM
Chips id................................ : 2CC30832EA30
Vendor.................................. : Micron
Type.................................... : 176L(B47R) TLC
Loader uploading
MPISP code name......................... : U0430A0 FIMB47_00; U0305A(N)
U0430A0 FIMB47_00; U0305A(N)............ : Ok
Invalid sectors per regions value (0xFFFF0000)
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0004); ECC error
Completed
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0001)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0003)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0009)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0015)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0019)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001B)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x001D............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0021)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0023............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0027)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0029............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002D)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x002F............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0033)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0035............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0039)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x003B............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0041............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0043)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0045)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0047............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0049)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x004B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0001)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0003)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0005............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0009)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x000B............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000F)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0011............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0015)................. : ECC error
SSD status:
Firmware mode........................... : LDR
Operation aborted
Utility initialization was terminate!
Re: Kingston SKC600/512 S4800105 SM2259H AC No correct loader
Posted: 03.01.25, 19:55
by Roman_TS
SM2259H is not listed between supported controllers...
https://blog.acelab.eu.com/pc-3000-ssd- ... dated.html
Posted: 12.01.26, 14:50
by italyassistance
Roman_TS wrote:Source of the post SM2259H is not listed between supported controllers...
News for SM2259H?
Posted: 13.01.26, 09:07
by Roman_TS
italyassistance wrote:Source of the post News for SM2259H?
Will be supported in 7.8x update in January-February 2026. But SM2259H is not universal controller. I doubt about Kingston modification, but Crucial BX500 SM2259H will appear.
