Kingston 120GB SM2258XT
Posted: 04.12.23, 03:58
by gameboybin
My 2nd time encountering this chip Type: Intel 32L(L06B) MLC
No current loaders for this type. I thought i will post this here for better search and soluions in the future
Chips id................................ : 89A46432AA01
Vendor.................................. : Intel
Type.................................... : 32L(L06B) MLC
Loader uploading
MPISP code name......................... : S1007A0 IM3D_00; S0104E(N)
S1007A0 IM3D_00; S0104E(N).............. : Ok
Calling executable code................. : Ok
Seed table reading
Completed
Microcode reading (0)................... : Ok
Firmware version (Internal)............. : Q0120B IM3D_00
SSD parameters reading.................. : Ok
Ready state waiting..................... : Ok
Q0120B IM3D_00; Q0123A(N)............... : Ok
Reset SSD controller.................... : Ok
Config Package.......................... : Ok
Q0120B IM3D_00; P1228(D)................ : Ok
Calling executable code................. : Command execution error; Write sector error (LBA: 21 930); HDD DMA Redynes timeout (10000)
Operation aborted
SSD status:
SSD is in ready state................... : No
Firmware mode........................... : Unknown
SSD is locked........................... : Unknown
SSD is in Safe Mode..................... : Unknown
Physical access is possible............. : No
Operation aborted
Loader is not uploaded! Some of the functions are not available!
Utility initialization was terminate!
Re: Kingston 120GB SM2258XT
Posted: 04.12.23, 09:11
by Roman_TS
Well, things are simple - ACELab developers add new loaders after each PC-3000 major release. The new version should be ready in the nearest time, so the new loaders will also appear.
Till that time, I doubt that it would be possible to find solution even if you post a request here. It's not working like this :)
Posted: 07.12.23, 03:00
by gameboybin
Roman_TS wrote:Source of the post Well, things are simple - ACELab developers add new loaders after each PC-3000 major release. The new version should be ready in the nearest time, so the new loaders will also appear.
My support date has just ended. Can i create Tickets just to inform TS Dev the new loaders, firmware that i encounter so for it might be added in the next PC3000 major update???
Posted: 07.12.23, 08:59
by Roman_TS
ACELab developers are not able to add loaders by request. They're usually researching all possible drives that they get in Lab, and add new loaders for upcoming new version release. There is a high chance that the required loader will appear after a major update.
