CP33238B (PS3111) support
Posted: 05.02.20, 06:17
I have 2 CP33238B (PS3111) cases and one of them with FW:SBFK71W0 while other one SBFK71W1. With FW:SBFK71W1 i have already recovered 60 % of data using Kingston A400 utility connecting directly to sata 0 port. with FW:SBFK71W0 i have tried to connect same way but its creating translator then when accessing the data its going to busy and all sector reading 00 00.Then I follow this instruction ==> https://blog.acelab.eu.com/pc-3000- ... ility.html and connetc through PATA ( utility SmartBuy Revival 2 ) and short safe mode pin and try to upload matching loader but its giving error.The error is below. I have tried this for both drive and same result. I tried to upload different loader also but same error. Anybody have same issue ?
Loader uploading
Code name............................... : Burner_PS3111_71.2.bin
Power Off
Power On
Safe mode............................... : Ok
Write seed.............................. : Ok
HDD Data timeout
Write HDD microcode .................... : Operation aborted
Operation aborted
SSD status:
SSD is in ready state................... : No
Firmware mode........................... : Unknown
SSD is locked........................... : Unknown
Techno mode is locked................... : Unknown
SSD is in Safe Mode..................... : Unknown
Physical access is possible............. : No
Operation aborted
Operation aborted
Loader uploading
Power Off
Power On
HDD Data timeout
Operation aborted
SSD status:
Operation aborted
Operation aborted
