Kingston Phison PS3108
Posted: 25.11.19, 12:56
by pclab
Hi Guys
I have this SSD with PS3108.
When I try to create a translator witn FW loader 3.8, I get a message of L2P table missing.
With the other 2 loaders, I only get errors...
Any hints?? Loader not correct?
SSD 8.3.log
(10.24 KiB) Downloaded 406 times
SSD 7.2.log
(35.39 KiB) Downloaded 388 times
SSD 3.8.log
(18.55 KiB) Downloaded 391 times
Re: Kingston Phison PS3108
Posted: 26.11.19, 06:48
by Roman_TS
Loader is correct, the problem is in damaged or erased L2P tables which includes information for translator rebuilding. Most likely drive is seriously damaged in FW part. Without L2P recovery will be not possible.
Posted: 13.05.21, 15:37
by otako
I know it's an old one, but had same "L2P table missing" issue with loader Burner_PS3108_8.3.bin or 3.8.bin
Did google it and that's how I end up here ;).
SSD drive I had is Silicon Power S60 with PS3108.
It worked fine with Burner_PS3108_7.2.bin, so maybe it's worth checking other loaders before giving up.
ssd.log
(18.51 KiB) Downloaded 317 times
Posted: 12.11.23, 09:24
by HEX
We have exactly the same problem.
Intenso SSD on the PS3108 controller with 98DEA48276D6 memory.
No L2P tables can be found on any Loader, generally the logs look the same as those posted by PCLAB.
In our opinion, this looks like incompatible software.
- Lukas -
