Kingston SKC600/512 S4800105 SM2259H AC No correct loader
Postby gameboybin » 03.01.25, 09:06
Exact same problem like in Lasek post. Still no correct loader for this SSD. I have tried every single one of them loaders. None of them Recognized the SSD as a 2x256GB chip SSD
Model : SM2259AC-80-10000001
Serial : (03)5526888-20080228
Firmware : 20141211
Capacity : 1 GB (2 096 640)
Selected family......................... : Silicon Power Slim S55 (SM2259XT)
Controller.............................. : SM2259XT
SSD status:
SSD is in ready state................... : Yes
Firmware mode........................... : ROM
SSD error code.......................... : 0x00 (No errors)
SSD is locked........................... : No
SSD is in Safe Mode..................... : Yes
Physical access is possible............. : No
Chips id................................ : 2CC30832EA30
Vendor.................................. : Micron
Type.................................... : 176L(B47R) TLC
Loader uploading
MPISP code name......................... : U0430A0 FIMB47_00; U0305A(N)
U0430A0 FIMB47_00; U0305A(N)............ : Ok
Calling executable code................. : Ok
Invalid sectors per regions value (0xFFFF0000)
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0004); ECC error
Completed
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0001)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0003)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0009)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0015)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0019)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001B)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x001D............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0021)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0023............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0027)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0029............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002D)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x002F............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0033)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0035............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0039)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x003B............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0041............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0043)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0045)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0047............ : Page is empty
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0049)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x004B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0001)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0003)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0005............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0009)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x000B............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000F)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0011............ : Page is empty
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0015)................. : ECC error
SSD status:
Firmware mode........................... : LDR
SSD is in Safe Mode..................... : No
Physical access is possible............. : Possibly
Operation aborted
Loader is not uploaded! Some of the functions are not available!
Utility initialization was terminate!
Re: Kingston SKC600/512 S4800105 SM2259H AC No correct loader
Postby Roman_TS » 03.01.25, 19:55
SM2259H is not listed between supported controllers...
https://blog.acelab.eu.com/pc-3000-ssd- ... dated.html
