Corsair Force LE 200 PHISON PS3111-S11-13
zeroalpha
Postby zeroalpha » 20.12.17, 01:58
I have been able to image this SDD to approximately 90% complete, however all sectors are zero filled for the full 250GB size. Whats the reason for this to be zero filled? Controller problem causing this type of output?
Re: Corsair Force LE 200 PHISON PS3111-S11-13
Postby Roman_TS » 20.12.17, 08:04
The most probable issue - translator corruption. Drive is working but there is no access to real internal data. Controller return the same pattern - zero filled page.
PS3111-s11 will appear in PC-3000 SSD closer to the Spring 2018
zeroalpha
Postby zeroalpha » 20.12.17, 10:41
Thanks Roman.
Postby Amarbir[CDR-Labs] » 21.12.17, 03:43
zeroalpha wrote:Source of the post I have been able to image this SDD to approximately 90% complete, however all sectors are zero filled for the full 250GB size. Whats the reason for this to be zero filled? Controller problem causing this type of output?
Hi ,
I would like to share this with you that you should take a sector at around 25% 50% or 75% LBA of Entire LBA ,then Write Something To That Sector And Save That Sector ,Then Read It If Its Able To Show You The Data You Saved Its Not a Controller Issue Its ZERO Filled Drive :D
Abdurrahim.sopon
Postby Abdurrahim.sopon » 30.10.20, 23:06
cpu :Phison PS3111-S11
suddenly STOPPED working .
ssd is detected with full capacity but all sectors show 00000.
hello everyone
anyone has any real experience with this cpu and same issue ?
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
Abdur rahim sopon
mobile:01912-881685
skype:rahim3720
Postby Roman_TS » 31.10.20, 12:00
Abdurrahim.sopon
Hello! This controller us fully supported. Contact ts.acelab.eu.com and our engineer will guide you.
Abdurrahim.sopon
Postby Abdurrahim.sopon » 06.11.20, 08:34
Roman_TS wrote:
Abdurrahim.sopon
i was try with PATA adaptor ssd show busy .
but when i connect it sata port it show ready and detected with full capacity .
i try to short pin with PATA Adapter but it always busy .
maybe my short pin out is wrong . (i use points under controller are shorting points)
Abdur rahim sopon
mobile:01912-881685
skype:rahim3720
Postby Roman_TS » 06.11.20, 10:50
Abdurrahim.sopon
Please upload the picture how did you connect your drive to PATA adapter.
Abdurrahim.sopon
Postby Abdurrahim.sopon » 06.11.20, 13:42
Abdurrahim.sopon
Thank you for your quick reply.
i will upload my PATA Adaptor picture .
Adaptor mcu number : DOF - B75KD0241
i lost my pc3000 IDE adaptor
Abdur rahim sopon
mobile:01912-881685
skype:rahim3720
Postby Roman_TS » 06.11.20, 14:48
Abdurrahim.sopon
Try to use other PATA to SATA adapters. This one doesn't work correctly.
But of course, always better to use official ACELab adapter - it always works.
Abdurrahim.sopon
Postby Abdurrahim.sopon » 07.11.20, 10:32
Abdurrahim.sopon
thank for your suggestion
Abdur rahim sopon
mobile:01912-881685
skype:rahim3720
rickchbz
Postby rickchbz » 08.07.21, 17:52
same problem in my patient A400 kingston with ps3111-s11-13, data user zero on extractor
maybe running quick analysis after that
Postby Roman_TS » 09.07.21, 10:29
rickchbz wrote:Source of the post same problem in my patient A400 kingston with ps3111-s11-13, data user zero on extractor
You should try to rebuild a translator in utility. If you already try that before, probably it make sense to try with other loaders.
Return to “Other SSD Corsair”
