SDSA5jk-256GB
Posted: 22.05.17, 20:07
by Wanderson
Good afternoon
I'm having an SSD with model SDSA5JK-256 GB
I would like to know which adapter I can connect to the PC3000
Re: SDSA5jk-256GB
Posted: 23.05.17, 09:01
by Roman_TS
This is Mini PCI-Express based drive. There is no adapter to SATA, because as we know, it does not contain SATA controller inside CPU, only PCI-E. But anyway, you can try to find adapter miniPCI-E to PCI-E - should works.
Re: SDSA5jk-256GB
Posted: 24.05.17, 09:56
by Roman_TS
This is a MacBook drive? Which model of Mac is it?
Re: SDSA5jk-256GB
Posted: 26.05.17, 12:28
Roman ,
Sir are these kinda drives also workable with the flash tool ?
Re: SDSA5jk-256GB
Posted: 29.05.17, 10:11
by Roman_TS
You mean recovery through chip-off? No. All modern SSD, especially based on PCI-E controller, have full hardware encryption by AES-256 key. Recovery will be not available at all - you will see only encrypted rubbish.
