Page 1 of 3
SandForce based SSD
Posted: 13.11.15, 15:57
by Roman_TS
A lot of our customers ask us about SandForce controller. Everyone want to know - when exactly we will add this SandForce SSD in support list?
The main problem of this type of SSD - very complicated internal structure with full hardware encryption of all logical structures. It means that such drive completely crypt all data in Firmware and in NAND memory chips. If you will try to unsolder NAND Flash chips from the SandForce based SSD, you will find that all information is completely encrypted with the AES-256 key.
At the same time - the SandForce 2281 become one of the most popular in SSD market -it was inexpensive and offered a good speed in writing and reading operations. That's why a lot of companies like Intel (Intel 520, 530 SSD), Kingston (SSDNow v300), Toshiba (rebranded TC controllers) and OCZ (Vertex 3) produced a lot of SSD models based on this type of CPU.
But the high speed and a good price were the only advantages of this CPU. Most of the drives based on SF 2281 become dead after 6-18 month of usage. Drive just goes into BSY state and don't make any signs of activity.
Lucky for us, nowadays this controller become not so popular as before, but it still can be found in Noname SSD drives produced in China, or in some value drives like Silicon Power, PNY, ADATA, SANDISK and others.
At this moment there is no way for getting data from such drives. But we still looking for the way of adding them in our support list.
There are some third-party companies where the ex-Seagate engineers are working. These engineers have access to Techno-Utility for SandForce, and they could help you to recover SandForce-based drives. But this way is expensive, pretty complex and almost completely manual. "One Button Solution" is not an option for SandForce drives.
Re: SandForce based SSD
Posted: 14.01.16, 14:52
by Roman_TS
List of known SSD based on Sandforce controller (the most popular brands):
A-DATA:
    S511 2.5" SATA 6Gb/s SSD
    S510 2.5" SATA 6Gb/s SSD
    Premier Pro SP900 2.5" SATA 6Gb/s SSD
    XPG SX900 2.5" SATA 6Gb/s SSD
    XPG SX910 2.5" SATA 6Gb/s SSD
    Premier SP800 2.5" SATA 3Gb/s SSD
    XM13 mSATA SSD
    XPG SX300 mSATA SSD
    Premier Pro SP300 mSATA SSD
AMP INC:
    Bay Bridge Internal miniSATA SSD (AMP341)
    SATAsphere 1.8" Micro SATA SSD
    SATAsphere 2.5" SATA II SSD
    SATAsphere Mini PCI-e 70mm SSD
    SATAsphere mSATA 70mm SSD
    SATAsphere mSATA 50mm SSD
    SATAsphere Slim SATA (MO-297A) SSD
Apacer:
    Turbo II Series — AS602 SSD
AXIOM:
    Axiom Signature Series SSDs
    Axiom 2.5" Hot-Swap SATA 6Gb SSD - Enterprise
Core Rise:
    Comay Pluto SX 3- 2.5" SATA 6Gb/s SSD with 5K PE NAND
    Comay Pluto CC 3- 2.5" SATA 6Gb/s Cloud Computing SSD with 5K PE NAND
    Comay Pluto SW 3- 2.5" SATA 6Gb/s SSD with eMLC NAND
    Comay Pluto SP 3- 2.5" SATA 6Gb/s Enterprise SLC SSD
    Comay Venus Pro 3- 2.5" SATA 6Gb/s Client SSD
    Comay Venus 3 - 2.5" SATA 6Gb/s Client SSD
    Comay Ceres Pro 3- mSATA SSD with Synchoronus MLC NAND
    Comay Ceres 3- mSATA SSD with Asynchoronus MLC NAND
Corsair:
    Accelerator Cache SSD Series SATA 3Gb/s SSD
    Force Series 3 SATA 6Gb/s SSD
    Force Series GT SATA 6Gb/s SSD
    Force Series GS SATA 6Gb/s SSD
    Force Seriese FX
KingSpec
    C3000
    E3000s
    E5000
    M5000
Kingston
    HyperX SSD
    HyperX 3K SSD
    SSDNow V+200 SSD
    SSDNow KC100
    SSDNow V300 SSD
OCZ
    Agility 3 SSD
    RevoDrive 3 PCI-Express SSD
    OCZ RevoDrive 3 X2 PCI-Express SSD
    Synapse Cache SATA III 2.5" SSD
    Vertex 3 SSD
    Vertex 3 Max IOPS SSD
    Z-Drive R4 C Series SSD
    Z-Drive R4 R Series SSD
    Agility 2 SSD
    IBIS Series High-Speed Data Link 3.5" SSD
    RevoDrive PCI-Express SSD
    RevoDrive X2 PCI-Express SSD
    VeloDrive PCI-Express SSD
    Vertex 2 SSD
    Vertex 2 EX Series SSD
    Vertex 2 Pro Series SSD
    Vertex 4
Patriot:
    Pyro SATA 6Gb/s SSD
    Pyro SE SATA 6Gb/s SSD
    Wildfire SATA 6Gb/s SSD
PNY:
    Prevail Series SSD
    XLR8 Series SSD
    XLR8 PRO Series SSD
Silicon Power:
    Velox Series V70 2.5” SATA 6Gb/s SSD
    Velox Series V30 2.5” SATA 6Gb/s SSD
    Velox Series V20 2.5” SATA SSD
+ at least we know that Intel 520, Intel 530 and Intel 535 also based on Sandforce.
Posted: 25.01.16, 12:53
by hddr49
You can add :
Corsair - Force series F60 (SF-1222TA3)
Posted: 11.05.16, 18:35
by DataSector
Also Intel 330 Series
Posted: 08.11.16, 04:11
by Consultant
Also:
SOLIDATA COMAX-M480 (SF-1222TA3)
Posted: 23.03.17, 16:52
by hdrescue
ADATA Model: XM11 6+12pin SSD (SP-2281VB1)
Posted: 11.04.17, 15:19
by cuumaytinh
Kington SandForce{200026BB}
Posted: 06.07.17, 12:37
by bcasol
Any updates on the ability to recover such drives?
Posted: 06.07.17, 17:32
by Roman_TS
Maybe in 2018. Keep watch our news :)
Posted: 30.07.18, 19:09
by pauloanbraga
Any news about SandForce support?
Posted: 31.07.18, 06:22
by Roman_TS
Some day - defenetly :D
Posted: 17.09.18, 22:07
pauloanbraga wrote:Source of the post Any news about SandForce support?
I can handle some cases of Sandforce controllers stuck busy. Certainly not in every case, but my trick has worked with a fair number of cases so far.
Posted: 31.10.18, 11:16
by pad-dataservice
Adding VTX3-25SA3 Vertex3 OCZ to list of shit drives
Posted: 02.11.18, 14:43
by lcoughey
I've helped several other labs with my method to get data recovered from many SandForce based SSDs for a lot less than the cost to send to couple of labs who are able to handle them for thousands. If the SSD just shows BSY right away, without first coming RDY, my method won't work. But, if it does come RDY, then go BSY when you try to read it, let me know and I'd be happy to help.
Posted: 06.03.19, 06:32
by se134
Any news?
