SM2259XT New Loader
Posted: 16.07.26, 16:51
by p4xel
Hi. I got a Netac SA500 SSD with SM2259XT2G controller chip and cannot find a loader for it in the utility
When it starts it picks FIM38B_00 loader, and after initial stage shows:
Code: Select all
Loader uploading
   Power Off
   Power On
   Safe mode............................... : Ok
   MPISP code name......................... : W0825A0 FIMN38_00 (XT2); W0621A(N)
   W0825A0 FIMN38_00 (XT2); W0621A(N)...... : Ok
   Seed table reading
   Completed
   Microcode reading (0)................... : Ok
   Firmware version (Internal)............. : X0419B0 FIM38B_00
   SSD parameters reading.................. : Ok
   Loader not found by internal name.
   Search for compatible loaders...
   Loader is not uploaded! Some utility functions may not work properly!
   SSD status:
   Firmware mode........................... : LDR
Test completed
Drive power supply...................... : OFF
But I don't see X0419B0 FIM38B_00 on the list, and if I select anything else it fails.
NAND chips:
Code: Select all
System Info:
Chips id................................ : 89D3AC32C204
Vendor.................................. : Intel
Type.................................... : 144L(N38) QLC 16k
Chip capacity........................... : 144 000 Mb
Channels................................ : 2
Chips (Total)........................... : 0x04
Planes per chip......................... : 4
LUNs per chip........................... : 1
Blocks per chip......................... : 0x00FA
Pages per block......................... : 0x9000
Page size............................... : 0x4000
Max retry level......................... : 0x00
Any help apreciated.
Re: SM2259XT New Loader
Posted: 16.07.26, 18:46
by italyassistance
Selection N38, and try all loader N38, if dont fuction your ssd have particular firmware but it is strange same standard SM2259XT2, u ask at TS team?
Posted: 17.07.26, 11:44
by p4xel
I tried many of them (IMN38, FIMN38 and EIMN38)
And not getting much success results with errors like
Microchips information uploading........ : Command execution error; Read sector error (LBA: 21 930); HDD DMA RQ timeout (10000)
Seed table reading
Completed
Firmware version (Internal)............. : O¾2 <-- FW version invalid
MPISP code name......................... : W0306B0 FIMN38_00 (XT2); W0308A(N)
W0306B0 FIMN38_00 (XT2); W0308A(N)...... : Ok
Seed table reading
Completed
It displayed the same loader selection window again, I selected the same loader and it started (kind of)
I am trying to create Translator. Will see how it goes.
Posted: 17.07.26, 11:58
by p4xel
I built the translator but when trying to read sectors in task I get those everywhere
Code: Select all
LBA 0; block: 0x0049; page: 0xAC87; Page marker checking error
LBA 8 696; block: 0x0052; page: 0x1CC2F; Page marker checking error
LBA 179 069 957; block: 0x00C2; page: 0x71CC; Page marker checking error
LBA 318 485 197; block: 0x00E8; page: 0xFC98; Page marker checking error
Posted: 17.07.26, 18:58
by italyassistance
version of software?
