Verbatim SATA III 1TB-Vi550 S3 all leds ON
Posted: 16.09.24, 15:05
by jojo2012
Hi everyone,
as per subject I have this 1TB Verbatim where after power ON all the status register LEDs are on.
The ctrl is a SM2259XT as you can see from the picture.
It looks like an electronic problem at the PCB.
What do you think? which component could be the culprit?
Re: Verbatim SATA III 1TB-Vi550 S3 all leds ON
Posted: 16.09.24, 21:57
by HEX
It could be anything.
Have you measured the voltages on the coils, capacitors?
If they are all there and after shorting the service pins there is still no response from the disk, then the controller is most likely damaged.
Posted: 17.10.24, 11:28
by jojo2012
HEX wrote:Source of the post
Solved. Data delivered. It was the SM2259XT.
Posted: 22.10.24, 21:19
by carlosmar
Did you replace the SM2259XT chip?
Posted: 10.03.25, 11:14
by jojo2012
Light reflow
