KingDian S280 120GB Translation Error
Postby gameboybin » 28.12.23, 04:50
Got this SSD with SM2285XT Controller
Has only 1 Nand chip however got recognized as 4 in PC3K
Recognized type as TLC however internally shows as SSV3. During choosing a loader none of SSV3 worked. However TLC 58 Worked
Model : SILICONMOTION SM2246XT
Serial : AA000000000000000339
Firmware : 20141127
Capacity : 117 GB (229 113 856)
Code: Select all
Selected family......................... : Crucial BX500
Controller.............................. : SM2258XT
SSD status:
Firmware mode........................... : ROM
SSD error code.......................... : 0x00 (No errors)
Chips id................................ : EC1C982F84C9
Vendor.................................. : Samsung
Type.................................... : 3dv3-48L TLC 16k
Loader uploading
   MPISP code name......................... : P0617B 58TLC_00; P0606A(N)
   P0617B 58TLC_00; P0606A(N).............. : Ok
   Seed table reading
   Completed
   Microcode reading (0)................... : Ok
   Firmware version (Internal)............. : R1001A0 SSV3_00
   SSD parameters reading.................. : Ok
   Loader not found by internal name.
   Search for compatible loaders...
   P0801A 58TLC_00; P0707A(N).............. : Ok
   Reset SSD controller.................... : Ok
   Config Package.......................... : Ok
   P0801A 58TLC_00; P0519(D)............... : Ok
   SSD status:
   Firmware mode........................... : DBG
Microchips information uploading........ : Ok
System Info:
Chip capacity........................... : 33 966 Mb
Channels................................ : 4
Chips (Total)........................... : 0x04
Planes per chip......................... : 2
LUNs per chip........................... : 1
Blocks per chip......................... : 0x075F
Pages per block......................... : 0x0480
Page size............................... : 0x4000
Max retry level......................... : 0x00
[color=#FF0000]First page not found
Reassigned block table loading.......... : Operation aborted[/color]
CP table loading
   [color=#FF0000]CP blocks not found[/color]
Completed
CP 0004 not found[/color]
ISP reading (Copy: 00)
[color=#FF0000]   channel: 0; chip: 0; block: 0x0000; page: 0x0001............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0003............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0007............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0009............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x000D............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x000F............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0013............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0015............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
   channel: 0; chip: 0; block: 0x0000; page: 0x0019............ : Invalid page index (0x00/0x0C)
   channel: 0; chip: 0; block: 0x0000; page: 0x001B............ : Invalid page index (0x00/0x0D)
   channel: 0; chip: 0; block: 0x0000; page: 0x001D............ : Invalid page index (0x00/0x0E)
   channel: 0; chip: 0; block: 0x0000; page: 0x001F............ : Invalid page index (0x00/0x0F)
   channel: 0; chip: 0; block: 0x0000; page: 0x0021............ : Invalid page index (0x00/0x10)
   channel: 0; chip: 0; block: 0x0000; page: 0x0023............ : Invalid page index (0x00/0x11)[/color]
Completed
ISP reading (Copy: 01)
 [color=#FF0000]  channel: 1; chip: 0; block: 0x0000; page: 0x0001............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0003............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0007............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0009............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x000D............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x000F............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0013............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0015............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
   channel: 1; chip: 0; block: 0x0000; page: 0x0019............ : Invalid page index (0x00/0x0C)
   channel: 1; chip: 0; block: 0x0000; page: 0x001B............ : Invalid page index (0x00/0x0D)
   channel: 1; chip: 0; block: 0x0000; page: 0x001D............ : Invalid page index (0x00/0x0E)
   channel: 1; chip: 0; block: 0x0000; page: 0x001F............ : Invalid page index (0x00/0x0F)
   channel: 1; chip: 0; block: 0x0000; page: 0x0021............ : Invalid page index (0x00/0x10)
   channel: 1; chip: 0; block: 0x0000; page: 0x0023............ : Invalid page index (0x00/0x11)[/color]
Completed
ISP reading (Copy: 02)
[color=#FF0000]   channel: 2; chip: 0; block: 0x0000; page: 0x0001............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0003............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0007............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0009............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x000D............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x000F............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0013............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0015............ : Page is empty
   channel: 2; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
   Page reading (channel: 2; chip: 0; block: 0x0000; page: 0x0019)................. : ECC error
   Page reading (channel: 2; chip: 0; block: 0x0000; page: 0x001B)................. : ECC error
   Page reading (channel: 2; chip: 0; block: 0x0000; page: 0x001D)................. : ECC error
   channel: 2; chip: 0; block: 0x0000; page: 0x001F............ : Invalid page index (0x00/0x0F)
   channel: 2; chip: 0; block: 0x0000; page: 0x0021............ : Invalid page index (0x00/0x10)
   channel: 2; chip: 0; block: 0x0000; page: 0x0023............ : Invalid page index (0x00/0x11)[/color]
Done with errors (3)
ISP reading (Copy: 03)
[color=#FF0000]   channel: 3; chip: 0; block: 0x0000; page: 0x0001............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0003............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0005............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0007............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0009............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x000B............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x000D............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x000F............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0011............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0013............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0015............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0017............ : Page is empty
   channel: 3; chip: 0; block: 0x0000; page: 0x0019............ : Invalid page index (0x00/0x0C)
   channel: 3; chip: 0; block: 0x0000; page: 0x001B............ : Invalid page index (0x00/0x0D)
   channel: 3; chip: 0; block: 0x0000; page: 0x001D............ : Invalid page index (0x00/0x0E)
   channel: 3; chip: 0; block: 0x0000; page: 0x001F............ : Invalid page index (0x00/0x0F)
   channel: 3; chip: 0; block: 0x0000; page: 0x0021............ : Invalid page index (0x00/0x10)
   channel: 3; chip: 0; block: 0x0000; page: 0x0023............ : Invalid page index (0x00/0x11)[/color]
Completed
ISP not found
Page reading (channel: 3; chip: 0; block: 0x0001; page: 0x0000)................. : Ok
MPINFO reading.......................... : Ok
Completed
Completed
Completed
ISP not found
Translator initialization
   Creating translator
 [color=#FF0000]     First page not found
      Operation aborted
      CP blocks not found
      CP 0004 not found
      Service area scanning
      Completed
   Blocks of translator is not found
Test interrupted
Re: KingDian S280 120GB Translation Error
SSD status:
Loader uploading
Seed table reading
Completed
SSD status:
System Info:
CP table loading
CP blocks not found
Completed
CP blocks not found
CP 0004 not found
Completed
Completed
Completed
ISP not found
Completed
Completed
Completed
ISP not found
Creating translator
Operation aborted
CP blocks not found
CP 0004 not found
Operation aborted
Completed
Test interrupted
Postby Roman_TS » 29.12.23, 13:58
Samsung NAND chips - usually loaders are not working good with them.
Return to “Other SSD”
