m2 SK hynix
Posted: 28.11.23, 10:46
by Southman343
Hi Friends
SK hynix (HFM256GDJTNG) BC501 with HFB1M8M0331A controller. I can't find contacts to transfer to safe mode. If someone has encountered this ssd, please help.
Re: m2 SK hynix
Posted: 28.11.23, 13:32
by Roman_TS
SAFE MODE will block access to NAND chips array, so you would be able work with the drive RAM + CPU. Not sure how exactly it should help :)
Re: m2 SK hynix
Posted: 29.11.23, 05:25
by Southman343
The problem is that the loader does not load due to an error in transferring the drive to safe mode, but thanks for the advice
Re: m2 SK hynix
Posted: 29.11.23, 08:13
by Roman_TS
But there is no Sk Hynix Utility in PC-3000 SSD, and no available loaders for this type of CPU.
It's a BGA-SSD drive, where controller, RAM and NAND chips are integrated into a common silicon layer.
