Just wonder if PC3K SSD support WD blue 4TB controller 88SS1074
Posted: 27.09.23, 22:01
by oldman
Just wonder if PC3K SSD support WD blue 4TB, controller is 88SS1074.
Thanks.
Phil
ps: seem that it is supported to 1TB only for controller 88SS1074.
Re: Just wonder if PC3K SSD support WD blue 4TB controller 88SS1074
Posted: 27.09.23, 22:04
by oldman
If I tried to run with 1TB,
[1] error message is
"Configuration........................... : ID 94 "VENUS 2.5FF 960GB 1Z eX3 2CE"
EEPROM read error (offset=0x00010000, size=512): Less than expected data transmitted
NAND flash chip ID read error (Ch=0, CE=0): Unexpected answer from drive"
[2] no terminal output with terminal 3 connected.
Thanks.
Phil
Posted: 28.09.23, 10:43
by Roman_TS
Hello Phil. Your drive is WD Blue 3D NAND?
Posted: 28.09.23, 16:58
by oldman
Hi Roman,
Yes, it is a WD Blue 3D NAND.
Thanks.
Phil
Posted: 29.09.23, 17:48
by Roman_TS
I'm afraid that WD Blue 3D NAND has it's own firmware with different SA/Transaltor Tables location. At this moment it's not supported, we can work only with the first generation - a common WD BLue.
Posted: 01.10.23, 00:38
by oldman
Thanks, Roman, good to know, checked the terminal many times and thought that maybe bad connection.
Phil
