GIGABYTE SSD bad sector
Posted: 05.05.21, 03:24
ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Roman_TS wrote:Source of the post Hello. Most likely current loader does not fit correctly. Did you try others?
thientankt wrote:Source of the post ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
otako wrote:Source of the postthientankt wrote:Source of the post ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Had any chance to try build loader with new PC-3000 SSD Ver. 2.10.2?
thientankt wrote:New Update SSD Support new firmware phison 3111. You can try
Code: Select all
Translator initialization
Creating translator
Read System Info........................ : Ok
Invalid channels count value (0x00)
Parameter "ChannelsCount"=0x01
Invalid chips count value (0x00)
Parameter "ChipsCount"=0x01
Invalid blocks per chip value (0x0000)
Parameter "BlocksPerChip"=0x0100
Invalid pages per block value (0x0000)
Parameter "PagesPerBlock"=0x0100
Invalid page size value (0x0000)
Parameter "PageSize"=0x4000Code: Select all
System Info:
Chips id................................ : 0x9BC348251000
Vendor.................................. : YMTC
Type.................................... : TLC 16k
Code: Select all
Translator build
Completed
Completed
Test completed
otako wrote:Source of the post With the loader SBFMP1.4 it worked like charm, no errors while uploading a loader or creating translator.
