SandForce based SSD
mikef
Re: SandForce based SSD
Postby mikef » 11.03.25, 18:17
Roman_TS wrote:Source of the post One day - definitely :)
Any near to a solution?
Postby Roman_TS » 12.03.25, 08:42
Maybe in the future :)
northwind
Postby northwind » 12.03.25, 09:27
We can do Sandforce with nearly 100% success rate :)
It's not easy job, though.
mikef
Postby mikef » 13.03.25, 09:29
northwind wrote:We can do Sandforce with nearly 100% success rate :)
I have already passed your details on to the client as the only Lab I knew of in Europe that worked on them and also warned them of the likely costs. He did say that he would contact you but you know what clients are like. :roll: Kingston hyperX fury, CL1382421?.
northwind
Postby northwind » 14.03.25, 08:34
mikef wrote:Source of the post
PM Sent.
Fraser Corrance
Postby Fraser Corrance » 22.07.25, 02:07
Wow.....that trick worked to get access to an SSD I am working on. Thnaks, Luke!
osity
Postby osity » 29.08.25, 20:34
Fraser Corrance
Was it a Sandforce?
MHS-Solutions
Postby MHS-Solutions » 03.12.25, 08:51
We also have a intel SSD 330 Series here, still hoping for a solution.
Our SSD is not recognized at all without testpoint shorted,
it just doesn't start.
With testpoint the controller is recognized well.
Postby gameboybin » 11.07.26, 10:10
2026 Here. Still no solutions. That is sad :cry:
Postby Roman_TS » 13.07.26, 09:59
SandForce-based drives almost disappear from the real recovery market. Single cases per month in our TS dpt - is nothing. So probably it does not make any sense to drive deep on such an ancient CPU researching. If someone needs a real SandForce recovery, there are a few companies with factory Seagate Utilities who can help.
northwind
Postby northwind » Yesterday, 12:39
We get an average of two Sandforce per month for recovery, so I wouldn't say they've disappeared..
Return to “Other SSD”
