Maxio MAS1102B-B1C
p4xel
Maxio MAS1102B-B1C
Postby p4xel » 22.07.26, 17:01
I am trying to upload a loader for this Chipset.
I selected a NAND B47R51229 (according to Flash.ini)
and when clicking [Next] to "Launching in Sage mode i just get an error at the bottom:
The service firmware uploading error: Cannot open file "D:\Resources\MaxioSSD\GDP\MAS1102\NAND\B47r_001_33.raw. The system cannot find the file specified
I checked that location and the file is not there. Is this a bug or am I missing the actual file that should be there?
Can anyone check if that file exists in your resources?
Thanks.
Re: Maxio MAS1102B-B1C
Postby Roman_TS » 23.07.26, 12:35
Seems that you tried to change some parameters manually, which isn't good. best clk should be 200.
But I recommend you to use Apacer profile for MAS1102 and B47R.
p4xel
Postby p4xel » 23.07.26, 17:16
I tried Apacer and manually select B47R
I set up Channel/CE map to 1 everywhere and started loader, and got this:
Code: Select all
Drive power supply...................... : OFF
Drive power supply...................... : ON
Utility mode............................ : Extended
SSD mode................................ : GDP
Tech-key................................ : Ok
Unknown NAND flash chips
Chip Id shows:
Code: Select all
Read ID
   Channel 0:
      CE 0.................................... : 2CD30832E8300000 (not in the memory chip database)
      CE 4.................................... : 2CD30832E8300000 (not in the memory chip database)
   Channel 1:
Test completed
According to ONFI it should be Micron’s B47R 176-Layer 3D TLC NAND
It seems to have similar geometry to these:
Name038=B47R06428 MT29F512G08EBLEE 0 2 1 2224 2112 16 1 2 0x2C 0xC3 0x08 0x32 0xEA 0x30 0 0 0 10 4 1500 001 1 11010 1968
Name039=B47R51229 MT29F4T08EULEE 0 2 1 4448 2112 16 2 2 0x2C 0xD3 0x89 0x32 0xEA 0x30 0 4096 0 10 4 1500 001 1 11010 1968
Is there a way to add it from spec sheet? Or is it added in new utility already?
Postby Roman_TS » 24.07.26, 10:43
Your chips are not B47R, they are B58R... These chips are not supported yet.
Name042=B58R12801 MT29F1T08EBLCH 0 2 1 3402 2784 16 1 2 0x2C 0xD3 0x08 0x32 0xE8 0x30
Return to “Other SSD”
