ECC ERROR | SM2258XT Topic is solved
hdrescue
Postby hdrescue » 22.05.24, 13:27
Is there any trick to find the correct loader or the ECC Error is not something that we can bypass?
I can't find any match with the type neither the info on the SSD back works as the firmware S1127B0.
These links don't help much in this case:
https://forum.acelab.eu.com/viewtopic.php?t=10909
https://blog.acelab.eu.com/pc-3000-ssd- ... t-xt2.html
Here is the log
Selected family......................... : KingDian S200
Controller.............................. : SM2258XT
SSD status:
SSD is in ready state................... : Yes
Firmware mode........................... : ROM
SSD error code.......................... : 0x00 (No errors)
SSD is locked........................... : No
SSD is in Safe Mode..................... : Yes
Physical access is possible............. : No
Chips id................................ : 0xEC519A3F8CCB
Vendor.................................. : Samsung
Type.................................... : 3dv4-64L TLC 16k
Loader uploading
MPISP code name......................... : S1127B0 HYNV4_00; S1129A(N)
S1127B0 HYNV4_00; S1129A(N)............. : Ok
Calling executable code................. : Ok
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 1; chip: 0; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 1; chip: 1; block: 0x0001; page: 0x0004); Command execution error; Read sector error (LBA: 21 930); DMA Data in command error. HDD Redynes timeout (10000)
Completed
Re: ECC ERROR | SM2258XT  Topic is solved
Postby Roman_TS » 22.05.24, 13:47
Drive is based on Samsung chips. I doubt that it would be possible to find a good loader for this drive.
Return to “Other SSD”
