I have San Disk SSD Plus (SM2246XT) that accepts loader and builds translator.
Shows that the it has certain amount of bad pages (thousands).
I set DE to ignore ECC errors.
Any sector that has no data (all zeroes) in it reads good (Green), any sector with data is ECC error.
I have tried freezing NANDs and it has no effect.
Any possible way to get around ECC errors on every sector with data?
I suspect that NANDs are too far gone?
Thank you for your time.
SanDisk SSD Plus ECC errors
- d_d_recovery
Re: SanDisk SSD Plus ECC errors
You can also try heating the NANDs and see if that makes a difference.
Heating the NAND chips with hot air up to +160C should help to reduce the errors.
blog.acelaboratory.com
