GIGABYTE SSD bad sector
thientankt
Postby thientankt » 05.05.21, 03:24
ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Thien Tan Data Recovery in Viet Nam
167 Tan Phuoc St 6 Ward, 10 Dist
Tel: (84)907 23 24 62
Skype/yahoo: thientankt
www.cuudulieuhcm.com |www.cuudulieuserver.net | www.phuchoidulieu.net
Re: GIGABYTE SSD bad sector
Postby Roman_TS » 05.05.21, 09:32
Hello. Most likely current loader does not fit correctly. Did you try others?
thientankt
Postby thientankt » 06.05.21, 10:22
Roman_TS wrote:Source of the post Hello. Most likely current loader does not fit correctly. Did you try others?
I try all Loader but the same result. I receive 6 ssd Gigabyte and all themes same.
Postby Roman_TS » 06.05.21, 11:24
Then, current firmware is too new and not completely compatible with existing loaders. Future updates will brings more PS3111 loaders, need to wait.
otako
Postby otako » 10.06.21, 10:39
thientankt wrote:Source of the post ssd GigaByte with Phison PS3111 Controller and new firmware SBFMP1.3 . I Can translator OK but 99% sector is Black.
Had any chance to try build loader with new PC-3000 SSD Ver. 2.10.2?
thientankt
Postby thientankt » 12.06.21, 09:54
otako wrote:Source of the post
New Update SSD Support new firmware phison 3111. You can try
otako
Postby otako » 15.06.21, 10:31
thientankt wrote:New Update SSD Support new firmware phison 3111. You can try
Yup it worked for me. I had a goodram with firmware SBFMP1.3. On older loaders it would not work at all.
Code: Select all
Translator initialization
   Creating translator
      Read System Info........................ : Ok
      Invalid channels count value (0x00)
      Parameter "ChannelsCount"=0x01
      Invalid chips count value (0x00)
      Parameter "ChipsCount"=0x01
      Invalid blocks per chip value (0x0000)
      Parameter "BlocksPerChip"=0x0100
      Invalid pages per block value (0x0000)
      Parameter "PagesPerBlock"=0x0100
      Invalid page size value (0x0000)
      Parameter "PageSize"=0x4000
With the loader SBFMP1.4 it worked like charm, no errors while uploading a loader or creating translator.
Code: Select all
System Info:
Chips id................................ : 0x9BC348251000
Vendor.................................. : YMTC
Type.................................... : TLC 16k
Code: Select all
     Translator build
      Completed
   Completed
Test completed
Now I have access to data.
TS with acelab is worth every penny.
Postby Roman_TS » 15.06.21, 18:54
otako wrote:Source of the post With the loader SBFMP1.4 it worked like charm, no errors while uploading a loader or creating translator.
Great to hear that solution is working. Actually, the most troublesome thing was the new NAND manufacturer - YMTC. We have never seen it before. Drives with these NAND chips have a different location of SA modules, which makes existing loaders to be useless. Anyway, we added it in a recent update - 6.9.10. Glad that you tried it and got the data!
sustek
Postby sustek » 16.07.21, 03:35
I confirm, just tried it on the same SSD (Patriot Burst) and it works! Good job! :thumbup:
dataclinicmx
Postby dataclinicmx » 20.07.21, 21:23
Hi i tried this one SILICON POWER S55 (PS3111), and worked for me !!
Return to “Other SSD”
