Sandisk Plus SM2256S Topic is solved
MicheleVitiello
Postby MicheleVitiello » 12.05.20, 09:17
Hello, we have this Sandisk SSD that we need to recover data from, I saw that this particular controller is not supported.
During power up it never reach ready state but remains BSY, I can put it in safe mode but it fails to upload the loader.
I tried with ADATA and AMD Radeon R3 utilities.
I attach pics of the drive.
Is there a way to recover data?
Do you think a chip-off and reading using PC-3000 flash will help?
Code: Select all
Model : SM2256AB-80-10000000
Serial : (03)5526888-20080228
Firmware : 20141211
Capacity : 1 GB (2 096 640)
Code: Select all
BASIC INFORMATION
Vendor.................................. : Sandisk
Type.................................... : 15nm TLC 16k
Chip capacity........................... : 1 024 Mb
Channels................................ : 1
Chips per channel....................... : 1
Planes per chip......................... : 1
LUNs per chip........................... : 1
Blocks per chip......................... : 0x0100
Pages per block......................... : 0x0100
Page size............................... : 0x4000
Max retry level......................... : 0x00
MEMORY MICROCHIP INFORMATION
:           :       Chip 0 :       Chip 1 :       Chip 2 :       Chip 3 :
: Channel 0 : 453E9AA37ED1 :              : 453E9AA37ED1 :              :
: Channel 1 : 453E9AA37ED1 :              : 453E9AA37ED1 :              :
: Channel 2 : 453E9AA37ED1 :              : 453E9AA37ED1 :              :
: Channel 3 : 453E9AA37ED1 :              : 453E9AA37ED1 :              :
Attention! The specified number of chips (1) does not correspond to the number of detected chips (8)!
Re: Sandisk Plus SM2256S  Topic is solved
Postby Roman_TS » 12.05.20, 09:31
Hello!
Chip-off is useless for all modern SSD. There is no chance to recover at least a partial data without a good translator algorithm for block reconstruction.
For now this model is not supported. We can work with Sandisk Plus which is based on SM2246XT and Marvell 88SS1074. Other modifications are not supported right now.
sempre
Postby sempre » 17.12.20, 13:22
MicheleVitiello wrote:Source of the post Hello, we have this Sandisk SSD that we need to recover data from, I saw that this particular controller is not supported.
Code: Select all
Firmware : 20141211
Code: Select all
BASIC INFORMATION
I have the same problem! Do you have any solution currently ?? Loader or software that can recover data from this ssd?
nothing is impossible!
Postby Roman_TS » 17.12.20, 13:36
At this moment we can work with ADATA SP550 and Radeon R3 drives which are based on SM2256K controllers. Other models are not listed.
Return to “Other SSD”
