Power Failure M2 Sata Toshiba SSD kbg30zmv256g
Hemendra
Postby Hemendra » 20.07.19, 10:14
I have Toshiba 256GB M2 Toshiba SSD kbg30zmv256g.
The hdd is not detected. Behavior like NO hdd is connected with pc3k or like the power failure hdd.
I have tried to found faulty components and created the output voltage diagram.
Attached the image of m2 sata. How to recover the data?
Thanks,
M2 Sata Toshiba SSD kbg30zmv256g Voltage pin output
northwind
Re: Power Failure M2 Sata Toshiba SSD kbg30zmv256g
Postby northwind » 21.07.19, 07:10
This is NVMe. You need to connect it to motherboard.
Return to “Other SSD”
