I have a IBM IC35L036UWD210 with a damaged PCB.
I swapped PCB by 2 others I have here with same P/N, and when I start the drive, spins, shows 0 mb of size and when I try to enter utility by reading SA drive power down.
Anyone had this problem already?
Thanks.
IBM IC35L036UWD210
Moderator: Sergey_TS
Re: IBM IC35L036UWD210
These drives can have their PCB swapped with the donor's but if the donor has the same firmware version. Usually NV-Ram is an 8-leg pin. PC-3000 SCSI has more description about it.
The second thing you can try is to use Hot swap method for this drive. It is described on 4.9 , 4.10 Chapters in the manual for PC-3000 SCSI manual.
Very often this family has scratched surface problem
