HD Seagate 36GB SCSI, error command Translator Regeneration
Posted: 14.05.09, 14:00
by Alexandre Silveira
Dears,
I run the command "Translator", but how show in the picture 2, the result show error.
Alexandre Silveira
- This HDD recognizes with the capacity 48MB.
- 1.JPG (16.44 KiB) Viewed 21714 times
- Show error command "Translator"
- 2.JPG (27.22 KiB) Viewed 21733 times
Re: HD Seagate 36GB SCSI, error command Translator Regeneration
Posted: 11.12.09, 15:34
by misa
I have "compatible" problem !
Show me : "Medium Format Corrupted"
and error translator regeneration
How to do ?
Misa
Posted: 04.04.10, 20:57
by Vikas
What i do
1 Translator regenration
when it comes back
2 HPAto max ( Service area)
3 regenerate translators
Vikas
Posted: 09.10.13, 16:53
by Nadpc3k
i have exact the same problem: i could not see where is " HPA to MAX " how to do that i really need help in this regards.
Posted: 10.10.13, 10:21
For this specific problem you can repair with manual repair through Bustrace.
What are the full sense keys/codes you get?
Posted: 03.01.16, 20:54
by Nadpc3k
I have one Seagate SCSI 146GB hard drive with medium errors.... i tried my best to regenerate translator but no luck at all ... i did try the method written by VIKAS ... but it did not help at all ... it was a easy fix before. ? i can read all the modules OK.. when power up gives me p list errors .. it is not reading plist... utility gives option to upload plist .. can i trick the drives by uploading plist of other drive and regenerate the translators ... any help appreciated
Posted: 18.02.16, 16:43
by Filipp_TS
Nadpc3k wrote:Source of the post can i trick the drives by uploading plist of other drive and regenerate the translators ... any help appreciated
P-list module is unique list of defects and can't be taken from the donor drive/profile folder.
That's why the translator regeneration procedure doesn't fix the problem..
