HTS545032B9A300 problem
Posted: 02.02.18, 13:33
by emir_has
I have this disk and I dont know whats the problem is with it. When i power up it, it show drd less then second. It doesnt initialize properly when I start utility it shows error reading Tecno key and other parameters. When I order any command it shows error always. It doesnt spin up at all. I have check PCB it is ok and also I found donor PCB to check does it spin up and it not.
I have read blog article about PUIS drive and article didn't helped me. (http://blog.acelab.eu.com/drives-wi ... ature.html)
So can someone help me with this drive or give me some hint or something?
Re: HTS545032B9A300 problem
Posted: 06.02.18, 13:16
by Sergey_TS
emir_has, Do you choose correct family when you open Utility :?:
Posted: 06.02.18, 19:01
by emir_has
Yes I am. I have choosen right family!
Posted: 07.02.18, 09:07
by Sergey_TS
emir_has, did you try donor PCB without ROM / NV-RAM transferring? Also no spinning :?:
Posted: 13.03.18, 07:30
by emir_has
Yes I have tried without ROM /NV -RAM transfering nod spining.
Posted: 15.03.18, 10:03
by Sergey_TS
emir_has, try to isolate Head contacts with piece of paper and Power On. What about now :?:
Posted: 16.03.18, 20:25
by emir_has
Still no spining up with isolated heads
Posted: 21.03.18, 16:01
by Sergey_TS
emir_has, what about sounds after Power On? Probably Heads are stucked on the platters :shockable:
