Hitachi capacity appear MB ( )
Posted: 07.09.16, 12:29
Hi good afternoon,
Anybody like to try this issue?
My hitachi drive is not able to see the SA or userdata.
I can only the see
Model : HGST HTS725050A7E630
Serial : RC250ACB20239J
Firmware : GS2OA340
Capacity : MB ()
Selected family......................... : 7250A7
Model by ID............................. : HGST HTS725050A7E630
Techno mode key......................... : Error
ROM reading...
Possible Tech Key is found. Checking...
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
I did a head swap with a working donor drive.
The donor drive is still working, so the head in the patient drive before the head swap should be working.
I can only the see
Firmware : GS2OA340
Capacity : MB ()
ROM reading...
