HGST HTS725050A7E635 OPAL ( 0 MB )
Posted: 18.09.19, 14:10
by redlabs
WARNING! SET FEATURES subcommand required to spin-up after power-up!
Selected family......................... : 7250A7
Model by ID............................. : HGST HTS725050A7E635 OPAL
Techno mode key......................... : Error
ROM reading...
Possible Tech Key is found. Checking...
Error executing command: Reading SA [0x3F0000004, 0x4]
Device error detected "ABR"
Error reading module USAG(0): Error executing command: Reading SA [0x3F0000004, 0x1]
Error executing command: Reading SA [0x3F0100004, 0x4]
Error reading module USAG(1): Error executing command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
Dear Frds
The above error is coming while accessing hdd ,No head noise in the hdd kindly advise me in this problem
Re: HGST HTS725050A7E635 OPAL ( 0 MB )
Posted: 18.09.19, 21:03
Probably bad heads. If not that, then it's a corrupted modules table, which is even worse.
Posted: 23.12.21, 10:39
by d1d
DataMedics wrote:Probably bad heads. If not that, then it's a corrupted modules table, which is even worse.
how could i fix corrupted modules table ?
Posted: 25.12.21, 03:48
Typically you can't.
