Hitachi HDT721010SLA360 - no ID/incompatible USAG/NV-RAM after PCB-Swap
comasutra
Postby comasutra » 05.07.17, 18:15
Hello friends,
have a problem with a Hitachi HDT721010SLA360 Hard-Drive. The PCB was dead (not spinning), and the customer bought a donor-PCB (matching first two lines on the Sticker) and soldered U5 from old PCB to the new one. Now the drive is spinning but has no ID.
I could initialize the Drive by choosing the Family (HDx7210SL) and the "Switch SA Access"-Button. Could Read most modules (see Log). in DE Drive read with 99% Errors an extremly slow on all Heads. SA-Structure-Test shows following Errors:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
Report on module USAG, "Main module table"
ABA..................................... : FE020000
Length (sectors)........................ : 2
Loaded.................................. : Yes
Identified.............................. : Yes
mu-code................................. : ST6OA39N
FW Ver code............................. : 944ACF71
Incompatible with NV-RAM!
Report on module RAM0, "Code module"
ABA..................................... : FE020002
Length (sectors)........................ : 139
mu-code................................. : A39N
Incompatible with active USAG!
Report on module OVR1, "Code overlay module"
ABA..................................... : FE02008D
Length (sectors)........................ : 160
I tried the NV-RAM adjustment-method and rewrite PSHT and RDMT factory copy to 0 and 1 as described here http://forum.acelaboratory.com/viewtopic.php?t=7772#p26880 but nothing changed.
As Igor wrote here http://forum.acelaboratory.com/viewtopic.php?t=7398#p25619 "there are several bytes that can be changed in NV-RAM" ... NV-RAM is attached.
Does anyone have an idea?
Thanks in advance!
Boerge
NV-RAM.rar
(1.2 KiB) Downloaded 496 times
SA structure test.txt
(31.29 KiB) Downloaded 519 times
Sergey_TS
Re: Hitachi HDT721010SLA360 - no ID/incompatible USAG/NV-RAM after PCB-Swap
Postby Sergey_TS » 11.07.17, 22:24
comasutra, Both chips U5 and U7 should be resoldered here :umnik:
comasutra
Postby comasutra » 27.07.17, 17:49
Hi Sergey,
thanks for reply, but there is no U7-Chip soldered on both boards.
Sergey_TS
Postby Sergey_TS » 09.08.17, 15:17
comasutra, no need to worry about Factory copy incompatibilities.
But 1% of sectors is readable, correct? Where are these sectors located? In the HDD beginning, end or randomly? By one head or different heads?
