DT01ACA050 MS1OA8A0
Posted: 28.11.17, 02:57
by gmdata
I had HDD DT01ACA050 MS1OA8A0.
This HDD recognized PC3000.
capacity size and sectors is very good.
I could read succeed modulus and SA.
but I can't read data area.
I tryed changed RDMT, PSHD and "Initialize Translator in RAM".
Could you some adviced for me?.
Re: DT01ACA050 MS1OA8A0
Posted: 28.11.17, 14:26
by Sergey_TS
gmdata, did you check SA modules? You can attach log here, I will take a look :wink:
Posted: 28.11.17, 21:13
gmdata wrote:Source of the post I tryed changed RDMT, PSHD
What exactly do you mean by "changed RDMT, PSHD"?
Posted: 29.11.17, 02:12
by gmdata
Thank you. Sergey_TS and Data medics.
I send log data. I think that modules is good.
I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD.
But HDD was same. Can't read Data area.
20171129 PC3000 myoungseong 2.png (22.54 KiB) Viewed 11125 times
20171129 PC3000 myoungseong.png (28.3 KiB) Viewed 11125 times
Posted: 30.11.17, 17:16
by Sergey_TS
gmdata, SA looks OK here.
gmdata wrote:Source of the post I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD
It was a bad idea, because these modules are unique for every drive. Hope you backuped them. :shockable:
Please write them back!
Please check if all critical modules were uploaded into RAM (Sercvice Objects --> RAM) :!:
Is your drive with single head :?:
Posted: 01.12.17, 03:01
Sergey ,
This Drive is Single Head IMHO
Posted: 04.12.17, 03:26
by gmdata
Thank you. Sergey_TS and Amrbir.
The backed up file was written to the original HDD.
The head has one. I confirmed it on PC3000.
Posted: 04.12.17, 10:10
by Sergey_TS
gmdata, Most probably it's head degradation in your case, but did you check content of RAM as I mentioned before?
Posted: 13.12.17, 02:12
by gmdata
How do you check the data in RAM?
This hard is a firmware 8A0,
It is difficult.
Please let me know how to check the head ... Thank you.
