Toshiba DT01xxxx series
Posted: 04.01.16, 13:53
by jerovsek
which which family to select for DT01xxxx
Re: Toshiba DT01xxxx series
Posted: 11.01.16, 12:23
by Filipp_TS
try to use 7210DLE6 family.
Posted: 30.01.16, 08:44
by Imnew
Hello Filipp.
I have same case. The HDD is Toshiba DT01ACA050. I have chosen 7210DLE6 family from Hitachi. I can read all the modules. But it is not allowing to image or not allowing to read data area. Please help
Posted: 30.01.16, 10:39
by drdoc
Model : TOSHIBA DT01ACA100
Serial : Y3J1MH1MS
Firmware : MS2OA750
Capacity : 931.51 GB (1 953 525 168)
PC3K V6
it doesnt detect family, wont read modules UNLESS I try family 5C10CLA3 first
Selected family......................... : 7210DLE6
Model by ID............................. : TOSHIBA DT01ACA100
PCB only start!
PCB only start!
Error reading module USAG(0): PCB only start!
PCB only start!
PCB only start!
Error reading module USAG(1): PCB only start!
Error : .............................................................. : Module USAG: no copies read!
Error : .............................................................. : PCB only start!
========== Here I try 5C10CLA3 first, then 7210DLE6 works
Selected family......................... : 5C10CLA3
Techno mode key......................... : Error
Loading the table of "open" modules................................... : Ok
Posted: 30.01.16, 13:39
by DataMedics
I guess that answers which Techno mode key it needs. You may have just helped Ace with this one. Good find!
Posted: 02.02.16, 14:56
by Filipp_TS
Hello Everybody,
If you still have a problem with solutions for these hitachi drives please contact Technical support dept: ts.acelab.eu.com
and we are check these cases detailed.
Posted: 12.02.18, 10:27
by vijayan
Yes Now
Same Case Solved Toshiba Hard Disk Toshiba Famliy Not Seleted Hitech Famliy Seleted Working Full Data Imaging Complied
TOSHIBA DT01ACA100.JPG (61.51 KiB) Viewed 18021 times
Posted: 20.02.18, 12:47
by Filipp_TS
Because of DT**** toshiba drives are not Toshiba drives actually.
They are have Hitachi architecture, that's why for all DT*** drives need to use Hitachi ARM utility.
Posted: 25.02.18, 08:55
by Amarbir[CDR-Labs]
Its a hitachi drive period and you need to select " Tech Key " selection and unstick pcb only if thats selected ,Thats it you do not need to select any other family before this ,tech key detection is the key to this
