HTS725050A7E635 Sector not reading
Posted: 12.06.15, 10:45
by bikram
Hi All,
I have HTS725050A7E635 ALL Modules are ok but sector not reading i try through translator but result is same .
Selected family......................... : 7250A7
Model by ID............................. : HGST HTS725050A7E635 OPAL
Loading modules table................................................. : Ok
Loading the table of "open" modules................................... : Ok
Module RPSH Copy 0...................... : Ok
Module RPSH Copy 1...................... : Ok
Module USAG Copy 0...................... : Ok
Module USAG Copy 1...................... : Ok
Module RAMI Copy 0...................... : Ok
Module RAMI Copy 1...................... : Ok
Module RAM0 Copy 0...................... : Ok
Module RAM0 Copy 1...................... : Ok
Module PSHT Copy 0...................... : Ok
Module PSHT Copy 1...................... : Ok
Module RDMT Copy 0...................... : Ok
Module RDMT Copy 1...................... : Ok
Module RPOP Copy 0...................... : Ok
Module RPOP Copy 1...................... : Ok
Module SECI Copy 0...................... : Ok
Module SECI Copy 1...................... : Ok
Module SECB Copy 0...................... : Ok
Module SECB Copy 1...................... : Ok
Module ZONE Copy 0...................... : Ok
Module ZONE Copy 1...................... : Ok
Module SRVP Copy 0...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module CHNM Copy 0...................... : Ok
Module CHNM Copy 1...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Ok
Module SMRT Copy 0...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module IOPS Copy 0...................... : Ok
Module IOPS Copy 1...................... : Ok
Module SSLD Copy 0...................... : Ok
Module SSLD Copy 1...................... : Ok
Module SCTH Copy 0...................... : Ok
Module SCTH Copy 1...................... : Ok
Module FEAT Copy 0...................... : Ok
Module FEAT Copy 1...................... : Ok
Module CNFG Copy 0...................... : Ok
Module CNFG Copy 1...................... : Ok
Module WWNM Copy 0...................... : Ok
Module WWNM Copy 1...................... : Ok
Module RPSP Copy 0...................... : Ok
Module RPSP Copy 1...................... : Ok
Module SPTR Copy 0...................... : Ok
Module SPTR Copy 1...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module DBGC Copy 0...................... : Ok
Module DBGC Copy 1...................... : Ok
Module ALSM Copy 0...................... : Ok
Module ALSM Copy 1...................... : Ok
Module ATIR Copy 0...................... : Ok
Module ATIR Copy 1...................... : Ok
Module AVZN Copy 0...................... : Ok
Module AVZN Copy 1...................... : Ok
Module CGDF Copy 0...................... : Ok
Module CGDF Copy 1...................... : Ok
Module AMPM Copy 0...................... : Ok
Module AMPM Copy 1...................... : Ok
Module RDM1............................. : Ok
Module RDM2............................. : Ok
Module ELG1............................. : Ok
Module EVLG............................. : Ok
Module PID1............................. : Ok
Module PID2............................. : Ok
Module PIDM............................. : Ok
Module HLR1............................. : Ok
Module HLR2............................. : Ok
Module MFGP............................. : Ok
Module MFGT............................. : Ok
Module DMP1............................. : Ok
Module SDM1............................. : Ok
Module SVLG............................. : Ok
Module DDD0............................. : Ok
Module DIAG............................. : Ok
Module WRT0............................. : Ok
Module WRT1............................. : Ok
Any one any solution please help ....
Re: HTS725050A7E635 Sector not reading
Posted: 31.08.15, 14:22
by JiS
HI, Have you solved it?
I have the same issue. I think it has to be something with the Plist as i can read a few sectors in the middle of the drive, others are UNC.
I tried RAM translator for both copies without luck.
Posted: 01.09.15, 09:54
Try to patch translator using plist saved to file and not from HDD.
Posted: 03.09.15, 08:53
by bikram
YES !
Problem is Solve after Washing the platter problem solve .......
Posted: 17.09.15, 04:13
by LarrySabo
"Washing the platter"? Can you explain or elaborate, please.
Posted: 13.11.15, 14:19
by Filipp_TS
Dear Larry,
You can find a solution here:
http://ts.acelab.eu.com/index.php?/ ... g-platters
