HTS545050A7E380 ID OK, data UNC
Posted: 05.04.14, 13:11
by drmilos
**********UPDATE**************************
This was a case of bad/weak head. I have managed to clone head 1 and some data from head 0 using DE.
I am working on HTS545050A7E380.
On power up drive clicks twice and becomes ready.
On utility start drive shows correct ID and family and Techno Mode Key error (ERR/ABR).
When I check Tech Key detection box and start utility I am getting
Selected family......................... : 5450A7
Model by ID............................. : Hitachi HTS545050A7E380
Techno mode key......................... : Error
ROM reading...
Possible Tech Key is found. Checking...
Loading modules table................................................. : Ok
Loading the table of "open" modules................................... : Ok
I can back up all modules and SA Structure Test gives the report:
ROM VER................................. : 6C0
NV-RAM ID............................... : 2002GG22B6C0
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
ID...................................... : E2PR
mu-code................................. : 2002GG22B6C0
FW Ver (part 2)......................... : ³ 2
Heads................................... : 2
Head map................................ : 0 1 F F F F F F F F
Used module table
Report on module USAG, "Main module table"
ABA..................................... : 3F0000004
Length (sectors)........................ : 6
Identified.............................. : Yes
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : : (original) : (sect): (sect): (byte) : RAM : : :
RPSH : 0 : B : 3F0000000 : 3F0000000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RPSH : 1 : B : 3F0100000 : 3F0000000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
USAG : 0 : B : 3F0000004 : 3F0000004 : 6 : 6 : 0 : 00000000 : Yes : Ok : Main module table
USAG : 1 : B : 3F0100004 : 3F0000004 : 6 : 6 : 0 : 00000000 : Yes : Ok : Main module table
RAMI : 0 : : 3F000000A : 3F000000A : 128 : 128 : 56312 : 0001A408 : Yes : Ok :
RAMI : 1 : : 3F010000A : 3F000000A : 128 : 128 : 56312 : 0001A408 : Yes : Ok :
RAM0 : 0 : B : 3F000008A : 3F000008A : 1024 : 1024 : 524288 : 0086C600 : Yes : Ok : Code module
RAM0 : 1 : B : 3F010008A : 3F000008A : 1024 : 1024 : 524288 : 0086C600 : Yes : Ok : Code module
PSHT : 0 : Ad : 3F0001400 : 3F0001400 : 1600 : 1600 : 357640 : 00800800 : Yes : Ok : P-List module
PSHT : 1 : Ad : 3F0101400 : 3F0001400 : 1600 : 1600 : 357640 : 00800800 : Yes : Ok : P-List module
RDMT : 0 : Ad : 3F0001A40 : 3F0001A40 : 256 : 256 : 40960 : 00908600 : Yes : Ok : G-List module
RDMT : 1 : Ad : 3F0101A40 : 3F0001A40 : 256 : 256 : 40960 : 00908600 : Yes : Ok : G-List module
RPOP : 0 : : 3F0000498 : 3F0000498 : 2 : 2 : 420 : 0008487C : Yes : Ok :
RPOP : 1 : : 3F0100498 : 3F0000498 : 2 : 2 : 420 : 0008487C : Yes : Ok :
SECI : 0 : B : 3F0008BA0 : 3F0008BA0 : 3 : 3 : 1536 : 0092C000 : Yes : Ok : Security information module
SECI : 1 : B : 3F0108BA0 : 3F0008BA0 : 3 : 3 : 1536 : 0092C000 : Yes : Ok : Security information module
SECB : 0 : : 3F0008BA3 : 3F0008BA3 : 3 : 3 : 1536 : 0092C000 : Yes : Ok :
SECB : 1 : : 3F0108BA3 : 3F0008BA3 : 3 : 3 : 1536 : 0092C000 : Yes : Ok :
ZONE : 0 : Ad : 3F0000566 : 3F0000566 : 128 : 128 : 34816 : 0091D000 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 3F0100566 : 3F0000566 : 128 : 128 : 34816 : 0091D000 : Yes : Ok : Zone allocation table module
SRVP : 0 : B : 3F0000494 : 3F0000494 : 4 : 4 : 698 : 00925800 : Yes : Ok :
SRVP : 1 : B : 3F0100494 : 3F0000494 : 4 : 4 : 698 : 00925800 : Yes : Ok :
SRVM : 0 : Ad : 3F00004A3 : 3F00004A3 : 30 : 30 : 6466 : 00926000 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 3F01004A3 : 3F00004A3 : 30 : 30 : 6466 : 00926000 : Yes : Ok : Module contains cylinder defects table
CHNM : 0 : Ad : 3F00004C1 : 3F00004C1 : 165 : 165 : 32752 : 00915000 : Yes : Ok :
CHNM : 1 : Ad : 3F01004C1 : 3F00004C1 : 165 : 165 : 32752 : 00915000 : Yes : Ok :
IDNT : 0 : B : 3F0000492 : 3F0000492 : 2 : 2 : 584 : 0092BC00 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 3F0100492 : 3F0000492 : 2 : 2 : 584 : 0092BC00 : Yes : Ok : HDD ID data module
SMRT : 0 : B : 3F0008B8E : 3F0008B8E : 8 : 8 : 4096 : 0092D400 : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 3F0108B8E : 3F0008B8E : 8 : 8 : 4096 : 0092D400 : Yes : Ok : S.M.A.R.T. module
SERL : 0 : B : 3F0008B89 : 3F0008B89 : 3 : 3 : 1536 : 0092CE00 : Yes : Skip : S.M.A.R.T. error log module
SERL : 1 : B : 3F0108B89 : 3F0008B89 : 3 : 3 : 1536 : 0092CE00 : Yes : Skip : S.M.A.R.T. error log module
IOPS : 0 : : 3F0008B9E : 3F0008B9E : 2 : 2 : 1024 : 0092C600 : Yes : Ok :
IOPS : 1 : : 3F0108B9E : 3F0008B9E : 2 : 2 : 1024 : 0092C600 : Yes : Ok :
SSLD : 0 : : 3F0008B8C : 3F0008B8C : 2 : 2 : 1024 : 0092E600 : Yes : Ok :
SSLD : 1 : : 3F0108B8C : 3F0008B8C : 2 : 2 : 1024 : 0092E600 : Yes : Ok :
SCTH : 0 : : 3F0008BA6 : 3F0008BA6 : 1 : 1 : 0 : 00000000 : Yes : Ok :
SCTH : 1 : : 3F0108BA6 : 3F0008BA6 : 1 : 1 : 0 : 00000000 : Yes : Error :
FEAT : 0 : : 3F0008B96 : 3F0008B96 : 8 : 8 : 360 : 00912600 : Yes : Ok :
FEAT : 1 : : 3F0108B96 : 3F0008B96 : 8 : 8 : 360 : 00912600 : Yes : Ok :
CNFG : 0 : : 3F0000490 : 3F0000490 : 2 : 2 : 654 : 00913600 : Yes : Ok :
CNFG : 1 : : 3F0100490 : 3F0000490 : 2 : 2 : 654 : 00913600 : Yes : Ok :
WWNM : 0 : : 3F00005E6 : 3F00005E6 : 1 : 1 : 54 : 0092BF00 : Yes : Ok :
WWNM : 1 : : 3F01005E6 : 3F00005E6 : 1 : 1 : 54 : 0092BF00 : Yes : Ok :
RPSP : 0 : : 3F000049A : 3F000049A : 8 : 8 : 2276 : 00913A00 : Yes : Ok :
RPSP : 1 : : 3F010049A : 3F000049A : 8 : 8 : 2276 : 00913A00 : Yes : Ok :
SPTR : 0 : : 3F000048A : 3F000048A : 2 : 2 : 0 : 00000000 : Yes : Ok :
SPTR : 1 : : 3F010048A : 3F000048A : 2 : 2 : 0 : 00000000 : Yes : Ok :
ABLP : 0 : B : 3F00004A2 : 3F00004A2 : 1 : 1 : 180 : 00914A00 : Yes : Ok :
ABLP : 1 : B : 3F01004A2 : 3F00004A2 : 1 : 1 : 180 : 00914A00 : Yes : Ok :
DBGC : 0 : : 3F000048C : 3F000048C : 4 : 4 : 1024 : 00914C00 : Yes : Ok :
DBGC : 1 : : 3F010048C : 3F000048C : 4 : 4 : 1024 : 00914C00 : Yes : Ok :
ALSM : 0 : : 3F00005E7 : 3F00005E7 : 4 : 4 : 2048 : 0092B000 : Yes : Ok :
ALSM : 1 : : 3F01005E7 : 3F00005E7 : 4 : 4 : 2048 : 0092B000 : Yes : Ok :
ATIR : 0 : : 3F00005EB : 3F00005EB : 20 : 20 : 4246 : 00928800 : Yes : Ok :
ATIR : 1 : : 3F01005EB : 3F00005EB : 20 : 20 : 4246 : 00928800 : Yes : Ok :
AVZN : 0 : : 3F00010D5 : 3F00010D5 : 1 : 1 : 4 : 00000000 : Yes : Error :
AVZN : 1 : : 3F01010D5 : 3F00010D5 : 1 : 1 : 4 : 00000000 : Yes : Error :
CGDF : 0 : : 3F0008BA7 : 3F0008BA7 : 8 : 8 : 4 : 0092EA00 : Yes : Ok :
CGDF : 1 : : 3F0108BA7 : 3F0008BA7 : 8 : 8 : 4 : 0092EA00 : Yes : Ok :
RDM1 : : Ad : 3F0001A40 : 3F0001A40 : 80 : 80 : 0 : 00000000 : Yes : Ok : G-List module (RDM1 - reference to RDMT)
RDM2 : : Ad : 3F0101A40 : 3F0101A40 : 80 : 80 : 0 : 00000000 : Yes : Ok : G-List module (copy)
ELG1 : : C : 3F0002700 : 3F0002700 : 512 : 512 : 0 : 00000000 : Yes : Skip : Log module
EVLG : : C : 3F0002900 : 3F0002900 : 512 : 512 : 0 : 00000000 : Yes : Ok : Log module (event log)
PID1 : : D : 3F0000602 : 3F0000602 : 2 : 2 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PID2 : : D : 3F0100602 : 3F0100602 : 2 : 2 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PIDM : : D : 3F00005FF : 3F00005FF : 3 : 3 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PDM1 : : Ad : 3F0001400 : 3F0001400 : 1600 : 1600 : 0 : 00000000 : Yes : Ok : P-List module (PDM1 - reference to PSHT)
PDM2 : : Ad : 3F0101400 : 3F0101400 : 1600 : 1600 : 0 : 00000000 : Yes : Ok : P-List module (copy)
HLR1 : : B : 3F0001068 : 3F0001068 : 5 : 5 : 0 : 00000000 : Yes : Error : Factory tests log module (HLRC)
HLR2 : : B : 3F0101068 : 3F0101068 : 5 : 5 : 0 : 00000000 : Yes : Error : Factory tests log module (HLRC, copy)
MFGP : : Dr : 3F0003E00 : 3F0003E00 : 1 : 1 : 0 : 00000000 : Yes : Error : Self Test parameters module
AMPM : : B : 3F0001003 : 3F0001003 : 1 : 1 : 0 : 00000000 : Yes : Error : Factory tests log module (AMPM)
MFGT : : : 3F0016421 : 3F0016421 : 1 : 1 : 0 : 00000000 : Yes : Error :
DMP1 : : : 3F0010700 : 3F0010700 : 4096 : 4096 : 0 : 00000000 : Yes : Error :
SDM1 : : : 3F0011700 : 3F0011700 : 4096 : 4096 : 0 : 00000000 : Yes : Error :
SVLG : : : 3F0012B00 : 3F0012B00 : 1024 : 1024 : 0 : 00000000 : Yes : Ok :
DDD0 : : B : 3F0001000 : 3F0001000 : 2 : 2 : 0 : 00000000 : Yes : Skip : DDD utility log module
DIAG : : B : 3F0001004 : 3F0001004 : 100 : 100 : 0 : 00000000 : Yes : Skip : Native diagnostic utilities log module
WRT0 : : B : 3F0012700 : 3F0012700 : 15 : 15 : 0 : 00000000 : Yes : Skip : Marker at head 0
WRT1 : : B : 3F0112700 : 3F0112700 : 15 : 15 : 0 : 00000000 : Yes : Skip : Marker at head 1
Modules checking completed
Information about copy 0
Report on module FEAT
ABA..................................... : 3F0008B96
Length (sectors)........................ : 8
Capacity................................ : 976773168
Maximal LBA............................. : 976773167
AutoReassign............................ : OFF
Report on module IDNT, "HDD ID data module"
ABA..................................... : 3F0000492
Length (sectors)........................ : 2
FW Ver (part 1)......................... : GG2O
Model................................... : Hitachi HTS545050A7E330
Report on module WWNM
ABA..................................... : 3F00005E6
Length (sectors)........................ : 1
Serial.................................. : TA95123VC4SJXV
WWN..................................... : 5000CCA6F5C229DF
Information about copy 1
Errors are in modules STCH, AVZN, HLR1, HLR2, MFGP, AMPM, DMP1, SDM1
Any sector edit gives ERR/UNC
I have tried:
Clear SMART;
Disable Auto reassign;
HDD Translator initialization in RAM (with P-List only and both P and G-lists)
same result.
I do not have donor drive or firmware to replace the faulty modules.
Any ideas what else should I try? Can I solve this by deleting G list? Any advice much appreciated.
Re: HTS545050A7E380 ID OK, data UNC
Posted: 28.04.14, 14:31
If the media has weak heads and H0 is only partially readable, next after some image the media stops giving ID and knocks before DRDY status, then logical step next is you should assume some level of degrading and worsening of condition.
My advice is change heads before more attempts as you run risk of further damage to surface or other components.
Posted: 17.05.16, 16:42
by vijayan
No Change Head Fist Check Head maybe same head very Week stop head working head take image after week head read showly but same data lost possibles
GIven case feadback vijayan2006(at)gmail.com
