MQ02ABF050H READ PROBLEM
Posted: 05.11.20, 06:26
I received TOSHIBA MQ02ABF050H drive for recovery. It look like good sweep and can read CP data. but whole customer's data can't read. (ABR ERR) I connect serial and try HDD config (flash parameter cache) but it can't select (push).
Next I swapped ROM to our donor board and result was same... In that time any method have use PC-3000?
- Info.txt
- (475 Bytes) Downloaded 287 times
