Toshiba DT01ACA050 (Hitachi ARM 7210DLE6)
Posted: 01.08.19, 08:54
by ddcywf
hello,
My Toshiba DT01ACA050 (Hitachi ARM 7210DLE6) drive gives the following error on connection. It also do not show the HDD ID.
Selected family......................... : 7210DLE6
Model by ID............................. : <ID IS NOT READ>
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
Kindly help.
Logs status
Re: Toshiba DT01ACA050 (Hitachi ARM 7210DLE6)
Posted: 01.08.19, 17:57
Well,
Quit Utility Then Try Again Without Power Off ,If SAme Then Change Heads And Try
Posted: 04.08.19, 11:44
by digitalsupport
How does the drive behave, how are heads looking under microscope, is the drive spinning or clicking ?
Posted: 07.08.19, 09:06
by ddcywf
digitalsupport wrote:Source of the post How does the drive behave, how are heads looking under microscope, is the drive spinning or clicking ?
No there is no noise of clicking and spinning from the drive
Posted: 24.04.24, 10:39
by gameboybin
I have the same issue. Even with the head changed. No noise. Drive is spinning
