TOSHIBA DT01ACA200 ROM & NVRAM
odedshankar
Postby odedshankar » 11.06.25, 04:04
I've got a 2TB TOSHIBA DT01ACA200 which is a rebranded Hitachi with PCB 220 QA90380 01.
The PCB is bad and i need to use a donor PCB.
I am assuming that i will need to move both ROM and NVRAM to the donor PCB.
I ROM Looks obvious but i am not sure which chip is the NVRAM, See photo.
Can you please confirm which chip stores the NVRAM.
HEX
Re: TOSHIBA DT01ACA200 ROM & NVRAM
Postby HEX » 31.10.25, 16:44
NVRAM acts as ROM (in simple terms). You only have one chip to transfer.
