TOSHIBA EARR
emir_has
TOSHIBA EARR
Postby emir_has » 09.01.25, 09:31
Can someone tell me what is this option in Toshiba utility "Enable EARR" / "Disable EARR" ?
Thank you
MasterT
Re: TOSHIBA EARR
Postby MasterT » 09.01.25, 15:11
Disabling ARRE should prevent the G-list from overflowing.
Side menu --> Disable EARR (terminal)
Keep in mind it does not survive Hard Reset or On/Off.
Alternative you can go in terminal and issue >SP command, you can check with terminal command >SF you should have (EARR:00) if it worked.
It does not work in all drives as I've noticed, especially the newer MQ04, some work, some don't.
