Toshiba DT01ACA050
stevan.vukovic
Toshiba DT01ACA050
Postby stevan.vukovic » 23.10.20, 13:05
with this HDD toshiba I use Hitachi-IBM-Arm utility = 7210DLE6
But what do you use to identify head compatibility?
If he can help, a photo from hdd is attached. :roll:
HDD Toshiba (small).jpg (81.16 KiB) Viewed 7605 times
Sergey_TS
Re: Toshiba DT01ACA050
Postby Sergey_TS » 30.11.20, 19:37
stevan.vukovic, Hello!
Actually these drives are not very sensitive for heads swap. I advise you to use same model drive AAH AA00 revison with close production date.
Also pay attention that this model can have 0 or 1 head map. Don't make a mistake :wink:
stevan.vukovic
Postby stevan.vukovic » 29.12.20, 19:59
Thanx Sergey!
