I need help with this drive DT01ACA100. When I start it there is no wierd noises, heads seams ok. But when I try to start utility Hitachi 7210DLE6 it report techno key ok but cannot read modules (CP)? On any comman it reports ABR error. I have read blog on acelab ( https://blog.acelab.eu.com/2045.html ) but no success in initializing this drive. Guys please help me this is my first Toshiba 3.5" in lab?
https://imgur.com/A66fa88
Toshiba DT01ACA100 initialization problem
Re: Toshiba DT01ACA100 initialization problem
Any help, hint or starting point? Please help me with this drive?
emir_has, Hello!
such issue can be related with different reasons. I can recommend you to start from checking PCB by comparing SN inside NV-RAM with the side bar codes (not label)
such issue can be related with different reasons. I can recommend you to start from checking PCB by comparing SN inside NV-RAM with the side bar codes (not label) With best regards
