Unable to unlock HTS541075A9E680
rogaland
Postby rogaland » 09.05.16, 11:28
Trying to unlock a Security-locked HTS541075A9E680.
I select the ARM utility selecting custom family.
This is what happens when I run the unlock procedure, removing the PCB when told by the utility:
ATTENTION! Security-locked HDD.
Selected family......................... : CUSTOM
Model by ID............................. : HGST HTS541075A9E680
Password unlocking
Switching HDD power supply ON
Waiting for PCB readiness...
Reading NV-RAM.......................... : Ok
Error HDD unlocking: Unsupported action (GetHeadAmnt) for NVR kind 0
Any ideas?
Filipp_TS
Re: Unable to unlock HTS541075A9E680
Postby Filipp_TS » 25.05.16, 11:33
Try to set big timeout value in Settings window and perform step again.
Also ask client is it really have a pssword 'cause if drive have damaged sector with password it think that passowrd is set and when you try to unlock the drive - drive can't to get access to this sector and show an error.
