Samsung HM500JI problem
odedshankar
Postby odedshankar » 18.10.18, 08:21
Hi Guys,
I have a Samsung 2.5" HM500JI/U which had faulty heads.
I swapped the heads and not getting the LED terminal messages anymore, but now the drive stays busy and give me the following terminal messages, so i am assuming a firmware corruption, did anybody experienced something similar to that?
mS1 00000003
A1O=5 A1G=453
O=506 S=3
SK C: 4682 H:0
mS1 00000003
SK C:101784 H:0
SoUL!
PK_4 C: 8493 H:0
mS1 00000003
A1O=5 A1G=454
O=505 S=0
SK C: 4690 H:0
[RESET:2]
*PA VID=0007 PN=0000 Rev=0004
PSL
U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=1
CLA #36/75
Handoff RPM=571
SPOK
mS1 00000003
A1O=9 A1G=425
O=514 S=2
SK C: 4707 H:0
Scan BS ..
Boot Sector Error! Take a default.
Loaded FIT ( 0: 0: 1)
Reso Table Loaded
RRO1X Read OK
| 115 | MOVLY001 | 1 | 0 | 10 | 1140 |
| 115 | MOVLY001 | 1 | 1 | 10 | 1140 |
| 115 | MOVLY001 | 1 | 2 | 10 | 1140 |
Overlay file read bad
Cheers
GuideRecovery
Re: Samsung HM500JI problem
Postby GuideRecovery » 18.10.18, 09:21
odedshankar wrote:Source of the post Boot Sector Error! Take a default.
try starting drive with headmap changing in RAM, hope it will help.
Wasim Zafar
https://mindmergepk.com
odedshankar
Postby odedshankar » 18.10.18, 09:56
thanks mate, already tried that before posting, getting the same result.
there are 2 lines in the log that may indicate the fault:
and
it is probably some overlay problem loading but i am not familiar enough with these drive to identify the problem, hope someone here in the forum can help.
cheers
GuideRecovery
Postby GuideRecovery » 18.10.18, 10:01
how many heads this drive is ?
if 4 heads have you tried all different combination of headmap ?
if 2 heads, than only option left is hotswap...
Wasim Zafar
odedshankar
Postby odedshankar » 18.10.18, 10:13
it has 4 heads, tried all the head map options.
also tried hot-swap, didn't work either, but the firmware is different between the donor and patient so probably that's the reason.
Takanashi_Hina
Postby Takanashi_Hina » 18.10.18, 19:31
Problem reading MOVLY001 module. Use donor MOVLY001 and make sure that MOVLY001 match ROM as well. If you replace ROM by donor ROM/PCB you should make sure that MOVLY001 match the same version of ROM. If MOVLY001 is damaged (most likely your case) you need to make sure that you get correct version of it to write to the drive. If you do have bad sectors on SA you might need to change MOVLY001 location on FIT, etc ...
odedshankar
Postby odedshankar » 18.10.18, 22:08
Thanks mate, i kept on researching it and managed to access the SA using hotswap after all using another donor and backup as much modules as i could - luckily i got MOVLY001 from Head 3 and managed to re-write it successfully to Head 0 copy, now i get access and started imaging, but drive is highly unstable so hopefully it will be good before this set of heads die again :-)
odedshankar
Postby odedshankar » 19.10.18, 12:07
this drive is super weird, i started imaging and did about 10% in good speed, then started to slow with many errors, i thought that the heads are getting weak as a result of a platter damage, so i used second donor to swap heads and put the heads back to the first donor.
With second set of heads imaging is still super slow speed as before, and the donor which i put back the heads is running without a single error - weird case.
As it progress i'll be 70 yo when its done, bummer.
Return to “Spin Point”
