Samsung HN-M101MBB slider stuck on insde platter
Posted: 09.07.18, 10:04
by murtazabawa
I have 1TB Samsung HNM101MBB drive for data recovery. bottom 2 heads 0-1 are with out slider. After looking closely inside the platter those sliders are stuck to platters.
I tried to shake the drive to remove sliders but it could not come out. Is there any way to get those out so that I can replace the heads and read the drive.
I am planning to get below platter extractor and holder for 280$. my questions are 1. removing the platters and putting back what precaution I need to have? 2. Do I need to keep the vertical alignment accurate or little bit offset will work? 3. Are these platter holders safe for platters as these probably hold platter by magnet.
Re: Samsung HN-M101MBB slider stuck on insde platter
Posted: 09.07.18, 13:54
by LarrySabo
Read the replies give on HDD Guru, Data-Medics and HDD Oracle forums to the same question. (Posting the identical question to multiple forums leave a mess of redundant answers.) Many people read the same (multiple) forums.
Posted: 15.07.18, 19:58
by murtazabawa
Thank you all for all your reply and suggestions.
Removed platters with the help of stickers, used the plastic stick to remove the slider and that's it.
Drive now imaging. :D
WhatsApp Image 2018-07-15 at 10.17.01 PM(2).jpeg (8.88 KiB) Viewed 11330 times
WhatsApp Image 2018-07-15 at 10.17.01 PM(1).jpeg (9.93 KiB) Viewed 11330 times
WhatsApp Image 2018-07-15 at 10.17.00 PM.jpeg (6.11 KiB) Viewed 11330 times
WhatsApp Image 2018-07-15 at 10.17.01 PM.jpeg (10.81 KiB) Viewed 11330 times
