Hello Ineed Burn for HD161HJ/SRP
Filipp_TS
Re: Hello Ineed Burn for HD161HJ/SRP
Postby Filipp_TS » 28.03.18, 17:01
Hello Marcos,
Samsung drives hasn't BURN resources on the board.
In other words BURN resources can't be created from the drive even if it's absolutely health.
Postby AJ2008 » 28.03.18, 17:04
what is the problem with the device? What symptoms does it show?
betty
Postby betty » 09.10.18, 08:45
hi AJ,
I have the same model with busy state and spinning.... giving the terminal below...
SPW 3.0G LinkOk!5V: 04928
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0005
DAC: 6882
SK C: 00019364
ENG>SRV>
SvoTbl Loaded
CL E85C CM E693 SL 0328 SM 0603
BD
FdtTbl Loaded
*** Break at 0x005A [from Trap]
005A: 001F
DBG>DBG>
I tried Head mapping , LE ,RT,,,, etc... But no luck...
Betty
Return to “Spin Point”
