ST1000LM024 can read in sector edit but not DE
Posted: 18.03.17, 18:28
by osity
What would cause the drive to be able to read sectors using "sector edit" in the utility but not in DE?
In DE I just get readiness loss error.
Re: ST1000LM024 can read in sector edit but not DE
Posted: 22.03.17, 04:10
by Amarbir[CDR-Labs]
Osity ,
Try To Set ector Read To 1 In DE In Your Case With Lower Read Speeds
Posted: 22.03.17, 19:17
by osity
Amarbir,
If you mean block size. I've tried that with no luck. I've also tried read timeouts as low as 60ms
Posted: 23.03.17, 03:52
osity wrote:Source of the post Amarbir,
Kindly disable head map in DE and then try might be it works also try pio mode " hardware tries " .Very Unique Problem BTW .
Posted: 23.03.17, 14:55
by osity
I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work,
Posted: 04.04.17, 15:53
osity wrote:Source of the post I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work,
Read What i Said "I am Saying Do Not Create a Head Map " Just Try Like This and If You Have Created Head Map Deselect That Not Deselect Heads
Posted: 04.04.17, 19:17
by osity
what does "If You Have Created Head Map Deselect That Not Deselect Heads" mean?
How would you disable the headmap after creating it without creating a new task?
