Samsung SP1203N Busy
Posted: 26.01.16, 11:50
by pclab
I have this Samsung that is always busy.
It spins OK, no clicks, no spin down.
I get this terminal:
SpnOk
DAC:-00410
H: +00000
SK C: 0000CC03
ENG>SRV>
SvoTbl Loaded
BD
ENG>LE
E:0001 - Inv Cmd
ENG>
I don't have a donor compatible here right now, so hot-swap is not possible for now.
Any other things I could do?
Re: Samsung SP1203N Busy
Posted: 30.01.16, 18:44
by pclab
Case solved and closed.
Posted: 25.09.16, 14:07
pclab wrote:Source of the post Case solved and closed.
Pclab ,
What Was The Issue ?How did You Solve This
Posted: 12.12.16, 11:17
by nasseri54
pclab wrote:Source of the post the post Case solved and closed.
How did You Solve This!?
Posted: 12.12.16, 15:20
by pclab
Bad PCB. Swapped for another.
