Samsun St1000LM024/AV!
Posted: 11.12.15, 15:49
by Nadpc3k
I have this drive 1 TB heads were week ,, i changed the heads but drive do not spin with its own pcb but spin ok with donor pcb but stay bsy ... so its looks like error of PRE-AMP mismatch
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
>>>Invalid PA VID
*PA VID=0006 PN=000D Rev=0001 Invalid Preamp
>>>Invalid PA VID
U
S_0PreampError
EPOK
UDed
PK_4 C: 0 H:0
Re: Samsun St1000LM024/AV!
Posted: 11.12.15, 15:51
by Nadpc3k
please pavel let me know
Posted: 11.12.15, 17:03
It is error of incompatible preamp. You can easily identify this by placing patient PCB on donor HDA / or donor PCB on patient HDA and if it does not spin and displays the same error then it is a bad donor.
Posted: 12.12.15, 22:00
by Nadpc3k
Thnaks AJ .. i know that but donor is very closly match except the DOB is 5 month aprt .. may be that is teh issue i try that if i find that
Posted: 05.04.16, 21:14
by Spark
Did You solved ? I got the same problem:
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 8MB
>>>Invalid PA VID
*PA VID=0011 PN=0009 Rev=0002- PA_LSI2958 Found
>>>Invalid PA VID
*PA VID=0011 PN=0009 Rev=0002- PA_LSI2958 FoundU
S_0PreampError
EPOK
UDed
PK_4 C: 0 H:0
LED 2A01
LED 2A01
LED 2A01
Posted: 29.04.16, 12:37
by Garry_TS
Hi all,
means incompatible heads. Check first terminal strings at donor and patient, they must be same.
LED 2A01
also means problem with preamplifier ("Preamp is out of order" according manufacturer). Probably you need a donor heads.
To be 100% sure that it's hardware malfunction you can try to get access to service area by burn if it's available for this model or try hotswap.
P.S. Our partners did a good article about good donors: http://www.donordrives.com/blog/matching-guide
