SAMSUNG ST500LM016
Posted: 01.10.15, 12:04
by geosou
How Can I solder the SATA adapter on a SAMSUNG ST500LM016, HN-M500XBB
Best regards
Re: SAMSUNG ST500LM016
Posted: 01.10.15, 12:55
USE pcb from HN-M500MBB
Posted: 18.10.15, 00:02
by geosou
Thank you for your reply AJ2008 i will try that
Posted: 24.11.15, 21:48
by Garry_TS
You have to find two differential paired PCB traces that are comming from USB bridge to main IC and unsolder 4 capacitors.
Same way like in ST2000LM005.
As alternative you can use any SATA PCB from same family with same processor.
