SATA PCB compatible with USB PCB BF41-00309A
Posted: 01.10.25, 23:04
by samirmattar
Hello everyone,
I’m working with an HM100UX HDD that had a broken head. I replaced the head and was able to access it via USB, as I don’t have the SATA board yet.
I would like to confirm: is the donor PCB part number BF41-00322A compatible with this HDD? Also, is this part number exclusive to the ST320LM000 HDD, or can it be used with other models as well?
Thank you in advance for your help! :D
Re: SATA PCB compatible with USB PCB BF41-00309A  Topic is solved
Posted: 02.10.25, 10:10
by DCDL
Samsung 100725482 ------> 100720903
Samsung 100740633 ------> 100739392 found on ST2000LM003 ( common label ) donor
Samsung 100760718 ------> 100720903
Samsung 100765396 ------> 100767980 found on ST2000LM003 ( uncommon label ) donor
Samsung BF41-00300A ------> BF41-00306A found on HM321HI donor
Samsung BF41-00309A ------> BF41-00322A Found on Donor HM100UI
Samsung BF41-00365A ------> BF41-00354A
Samsung BF41-00373A ------> BF41-00354A found on ST750LM022 donor
Samsung BF41-00325A ------> BF41-00315A
Samsung BF41-00311A ------> BF41-00322A (unconfirmed)
Samsung BF41-00357A ------> BF41-00315A
Hope this helps. First ROW is the USB PCB, then the SATA PCB.
Posted: 02.10.25, 14:07
by samirmattar
Hello, thank you very much for your help.
