HD161GJ-HD102GJ slow read problem
Posted: 08.03.23, 08:01
by jand_krmnl
First of all hello everyone. I am new in this field. I'm sorry if i express anything wrong.
The model of the disk is HD161GJ, with a capacity of 160 GB, but when we look at the pc3000, the model is HD102GJ and its capacity is 1TB. If we select the "only terminal" option when entering the utility of this disk, the model is still HD102GJ, but the capacity has improved to 160 gb. We backed up the modules and the rom. It gives unc error when reading the sector. but if we choose "use utility" we can read it. We are trying to copy from the data extractor, but it reads very slowly. How can we solve this situation? thank you all :wave:
Re: HD161GJ-HD102GJ slow read problem
Posted: 09.03.23, 18:29
by anekakeck
That seems like an issue with the PCB.. check the PCB is native and has not been changed before. You can do a straight swap with another PCB if you have a donor part in stock.
If your firmware code is for example, 2009.01 you need to keep it close to this for your donor part i.e. 2009.01 or 2008.12
