ST2000LM003 HN-M201RAD/D1 - LED 110B - Unlatch Fail -UD..StuckLD..Stuck -
LoboXus
Postby LoboXus » 11.08.20, 23:50
hello to all,
Why after trying a headswap i get this error, even when putting original heads BACK TO HDD i get this error, and i know heads are not stuck Hdd clicks.
Any help will be apreciated.
ActiveFW : 00
FWVer : 0001DDR detected:32MB
*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002
*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002U
S_0
PCBA I/O Voltage : 1.8V
PREAMP : 1.8V
FLASH : 8Mbit
KonaRev: TI 4.3
Kona FSYS divider: 1
VCore1 RCS Disable
VN on
VN off
SO_1
Set Target RPM = 5409(0000906Fh)
IS Max= 400 (001Dh)
SU Max= 810 (003Bh)
DefaultKval : 692 TargetKval : 2740
RPL......Done:5
RPA......Done:32/77
HO..Done @RPM= 635
RU......................................Done @RPM= 5402
ST..Skip
SUT= 1700
mS1 00000002
VDAC Offs K0 ............Done: -13
VN on
SHK on
VBEMF Offs .....Done
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= - 1
A1G= 1418 A2G= 7 SWG= 0
Rvcm= 11549 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:0
VDAC Offs K0 ............Done: -15
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= 1
A1G= 1421 A2G= 7 SWG= 0
Rvcm= 11568 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:1
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 24 SWO= 2
A1G= 1423 A2G= 7 SWG= 5
Rvcm= 11581 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:2
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 24 SWO= 1
A1G= 1426 A2G= 7 SWG= - 3
Rvcm= 11601 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:3
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= 6
A1G= 1426 A2G= 7 SWG= 12
Rvcm= 11601 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:4
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 24 SWO= 4
A1G= 1428 A2G= 7 SWG= 7
Rvcm= 11614 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:5
VDAC Offs K0 ............Done: -7
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 24 SWO= 8
A1G= 1428 A2G= 7 SWG= 14
Rvcm= 11614 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:0
VDAC Offs K0 ............Done: -9
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 22 SWO= 7
A1G= 1430 A2G= 7 SWG= 12
Rvcm= 11627 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:1
VN on
SHK on
VBEMF Gain ....Done
A1G= 1432 A2G= 7 SWG= 4
Rvcm= 11640 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:2
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= 3
A1G= 1434 A2G= 7 SWG= - 4
Rvcm= 11653 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:3
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= 4
A1G= 1433 A2G= 7 SWG= 11
Rvcm= 11646 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:4
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 23 SWO= 5
A1G= 1435 A2G= 7 SWG= 0
Rvcm= 11659 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:5
VN on
SHK on
VBEMF Gain ....Done
A1G= 1435 A2G= 7 SWG= 10
Rvcm= 11659 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:0
VN on
SHK on
VBEMF Gain ....Done
Rvcm= 11659 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:1
VN on
SHK on
VBEMF Gain ....Done
A1O= - 7 A2O= 24 SWO= 6
A1G= 1436 A2G= 7 SWG= 10
Rvcm= 11666 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:2
VN on
SHK on
VBEMF Gain ....Done
A1G= 1438 A2G= 7 SWG= 0
Rvcm= 11678 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load = 3000 mips
LD..Stuck
UD..Stuck
EPOK
VN off
SHK off
PK_3 C: 0 H:3
Unlatch Fail
EPOK
UDed
PK_4 C: 0 H:4
UDed
PK_4 C: 0 H:4
LED 110B
LED 110B
LED 110B
LED 110B
LED 110B
LED 110B
northwind
Re: ST2000LM003 HN-M201RAD/D1 - LED 110B - Unlatch Fail -UD..StuckLD..Stuck -
Postby northwind » 20.08.20, 08:31
Did you check the ramp? I have seen this error when the ramp was slightly deformed and heads couldn't unload from ramp.
Return to “Spin Point”
