ST1000LM024 BSY
Moderator: Garry_TS
karan
ST1000LM024 BSY
Postby karan » 31.01.20, 14:31
Need some help with this recovery ST1000LM024.
Drive stays BSY. I have also attached terminal dump for your advise.
Thank you for any help given.
View information about ROM dump
From file............................... : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\Samsung\M8E 2.5''\ST1000LM024\rom.bin
Information about dump
Dump size............................... : 524288 bytes
Firmware checksum....................... : Ok
FIPS offset............................. : 0x00001000
FIPS size............................... : 4096 bytes
FIPS checksum........................... : Ok
Firmware type........................... : Main Code
Original name........................... : 2AR1g86M.177
Platform Id............................. : 0x4D
Head map................................ : 0, 1, 2, 3
Test completed
Terminal Output:
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 FoundU
S_0SO_1
SPU@29'C,5049mV
IS=6
CLA ..36/89
HO..OK
HO RPM=572 OK
AC 1858
ST..OK
mS1 00000003
GT:424
SC(L):4158/58
BE.N:27
LD..OK
SK C: 3285 H:0
[D_ABORT:00000001][SP:00087EC4][LR:1005513C][CPU:0]
L:00086000 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086010 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086020 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086030 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086040 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086050 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086060 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086070 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086080 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086090 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860A0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860B0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860C0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860D0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860E0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000860F0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086100 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086110 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086120 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086130 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086140 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086150 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086160 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086170 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086180 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086190 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861A0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861B0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861C0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861D0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861E0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000861F0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086200 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086210 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086220 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086230 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086240 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086250 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086260 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086270 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086280 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086290 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862A0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862B0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862C0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862D0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862E0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000862F0 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086300 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086310 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086320 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086330 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086340 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086350 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086360 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086370 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086380 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:00086390 A0A0A0A0 A0A0A0A0 A0A0A0A0 A0A0A0A0
L:000863A0 00000000 1001E93B A0A0A0A0 000863E8
L:000863B0 00004713 90007300 00004713 00085C34
L:000863C0 00000001 6000011F 00000002 00000000
L:000863D0 FFFFFFFF 00017AB5 00017AB5 FFFFFFFF
L:000863E0 00000000 00000000 00000000 10019BAB
L:000863F0 00000000 00000000 00003210 A0A0A0A0
L:00086400 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086410 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086420 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086430 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086440 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086450 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086460 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086470 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086480 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086490 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864A0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864B0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864C0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864D0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864E0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000864F0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086500 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086510 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086520 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086530 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086540 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086550 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086560 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086570 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086580 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086590 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865A0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865B0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865C0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865D0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865E0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000865F0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086600 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086610 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086620 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086630 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086640 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086650 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086660 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086670 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086680 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086690 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866A0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866B0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866C0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866D0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866E0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000866F0 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086700 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086710 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086720 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086730 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086740 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086750 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086760 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086770 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086780 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:00086790 A1A1A1A1 A1A1A1A1 A1A1A1A1 A1A1A1A1
L:000867A0 A1A1A1A1 A1A1A1A1 000811E4 00000032
L:000867B0 A1A1A1A1 A1A1A1A1 00006400 00000032
L:000867C0 00000000 00000000 00017A19 6000011F
L:000867D0 00000000 00001000 4000011F 1001E8DB
L:000867E0 00000000 00000000 00000000 00000000
L:000867F0 00000000 00000000 00003210 A1A1A1A1
L:00086800 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086810 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086820 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086830 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086840 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086850 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086860 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086870 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086880 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086890 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868A0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868B0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868C0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868D0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868E0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000868F0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086900 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086910 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086920 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086930 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086940 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086950 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086960 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086970 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086980 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086990 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869A0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869B0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869C0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869D0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869E0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:000869F0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A00 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A10 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A20 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A30 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A40 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A50 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A60 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A70 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A80 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086A90 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AA0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AB0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AC0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AD0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AE0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086AF0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B00 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B10 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B20 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B30 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B40 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B50 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B60 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B70 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B80 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086B90 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086BA0 A2A2A2A2 A2A2A2A2 A2A2A2A2 A2A2A2A2
L:00086BB0 A2A2A2A2 A2A2A2A2 A2A2A2A2 6000011F
L:00086BC0 00000030 00000000 FFFFFFFF 00000000
L:00086BD0 00000000 00000000 00080FDA FFFFFFFF
L:00086BE0 00000000 00008F9B 00000000 00000000
L:00086BF0 00000000 00000000 00003210 A2A2A2A2
L:00086C00 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C10 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C20 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C30 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C40 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C50 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C60 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C70 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C80 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086C90 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CA0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CB0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CC0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CD0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CE0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086CF0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D00 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D10 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D20 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D30 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D40 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D50 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D60 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D70 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D80 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086D90 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DA0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DB0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DC0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DD0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DE0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086DF0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E00 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E10 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E20 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E30 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E40 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E50 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E60 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E70 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E80 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086E90 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086EA0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086EB0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086EC0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086ED0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086EE0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086EF0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F00 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F10 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F20 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F30 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F40 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F50 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F60 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F70 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F80 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086F90 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FA0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FB0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FC0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FD0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FE0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00086FF0 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00087000 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00087010 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00087020 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00087030 A3A3A3A3 A3A3A3A3 A3A3A3A3 A3A3A3A3
L:00087040 A3A3A3A3 A3A3A3A3 0000002B D0004370
L:00087050 0000010C 000000E4 00000000 00001C75
L:00087060 00000000 000123B1 00001C75 00000000
L:00087070 00000002 00000021 000889E0 00000001
L:00087080 00088664 00010A7D 00000001 00088628
L:00087090 000889E0 000127A5 00088220 00001C75
L:000870A0 00000000 00000000 00000021 000870FC
L:000870B0 00084400 00088AD2 00088A12 0008862A
L:000870C0 00088644 0008867E 00000000 00012F4D
L:000870D0 00000001 00000000 00000000 00000000
L:000870E0 00000040 00084484 00000000 00000000
L:000870F0 000804A8 000096DF 00000107 00000000
L:00087100 00000000 10022C6B 00040000 00000000
L:00087110 000812E8 00000066 00000000 00000000
L:00087120 00000066 1002353D 000812E8 00000066
L:00087130 00000000 00009CCB 00040000 00000000
L:00087140 000812E8 00000000 00000000 0000ADD7
L:00087150 00000000 00000000 000812E8 10023799
L:00087160 000812E8 1002366F 000812D8 0000A191
L:00087170 000812E8 90072200 00000000 00000000
L:00087180 000812E8 000815B8 000812D8 0000AFA3
L:00087190 000812E8 0008779C 00000000 00087710
L:000871A0 900B4E00 0000B195 00081258 0000B059
L:000871B0 00081254 FFFFFFFF 00055000 00000000
L:000871C0 00000000 100225CF 00000000 00088CA4
L:000871D0 0008779C 00010000 00085E10 00009605
L:000871E0 00000000 00000000 00000000 00000000
L:000871F0 00000000 00000000 00003210 A3A3A3A3
L:00087200 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087210 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087220 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087230 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087240 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087250 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087260 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087270 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087280 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087290 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872A0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872B0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872C0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872D0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872E0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000872F0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087300 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087310 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087320 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087330 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087340 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087350 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087360 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087370 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087380 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087390 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873A0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873B0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873C0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873D0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873E0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000873F0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087400 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087410 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087420 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087430 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087440 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087450 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087460 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087470 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087480 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087490 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874A0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874B0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874C0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874D0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874E0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000874F0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087500 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087510 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087520 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087530 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087540 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087550 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087560 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087570 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087580 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087590 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875A0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875B0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875C0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875D0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875E0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:000875F0 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087600 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087610 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087620 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087630 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087640 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087650 A4A4A4A4 A4A4A4A4 A4A4A4A4 A4A4A4A4
L:00087660 A4A4A4A4 A4A4A4A4 A4A4A4A4 6000011F
L:00087670 00020000 00000000 FFFFFFFF 1002251B
L:00087680 1002251B 00081258 00020000 00000000
L:00087690 00000000 10022533 00000000 900B4E00
L:000876A0 00000000 100225A3 A4A4A4A4 A4A4A4A4
L:000876B0 A4A4A4A4 A4A4A4A4 0008779C 00087710
L:000876C0 00087728 900B4E00 00000000 00088CA4
L:000876D0 0008779C 900B4FF8 00000001 00000000
L:000876E0 0008779C 0000B22D 00000000 0000B059
L:000876F0 0008779C 00087710 00087728 900B4E00
L:00087700 00000000 00088CA4 0008779C 900B4FF8
L:00087710 00000001 00000000 900B4E00 0008779C
L:00087720 00000003 1001FFFB 00000000 00000000
L:00087730 900B4E00 00000000 00000200 00000000
L:00087740 00005342 900B4FF8 900B4E24 900B4E00
L:00087750 000003E8 04000000 90008DA4 900084E4
L:00087760 00000000 00000000 00000000 1002026F
L:00087770 00088A16 10028E7B 0008865C 00011CED
L:00087780 D0003580 00000001 000889E0 00010A7D
L:00087790 00054502 00000001 000889E0 00000000
L:000877A0 0000F713 0000FFFF 000003E8 00010000
L:000877B0 FFFD3133 00000000 00000000 00000000
L:000877C0 00000000 10021173 0000FFFF 1001F0CF
L:000877D0 0000FFFF 00008CAF 0A1C08C3 00000000
L:000877E0 00000000 00000000 00000000 00000000
L:000877F0 00000000 00000000 00003210 A4A4A4A4
L:00087800 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087810 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087820 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087830 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087840 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087850 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087860 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087870 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087880 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087890 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878A0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878B0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878C0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878D0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878E0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:000878F0 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087900 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087910 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087920 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087930 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087940 A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
L:00087950 A5A5A5A5 A5A5A5A5 A5A5A5A5 6000011F
L:00087960 00000000 00000000 00002A04 00000000
L:00087970 00000000 00000000 00003210 A5A5A5A5
L:00087980 00001111 374CC49E 378B214E 576DDD10
L:00087990 ABDD750F 373C2E8A 68540F1D BDA3F79F
L:000879A0 499FF9AC 81FF10CE 82F60018 D31C7A7B
L:000879B0 B25BF114 744522B0 D54D1E11 6FA961FB
L:000879C0 051E3BEF B40E011A 3B125C95 B9FEC7F9
L:000879D0 97B78F7C 2100ABE5 7C932EC2 6EEBAEF7
L:000879E0 F7C7C0EE 29140D76 C05006DC 54DB431A
L:000879F0 38832739 17506C2B 1096F85B 5CDC3FD9
L:00087A00 5359535F 529CE005 8DCC6319 CD08977B
L:00087A10 FF2679AF B761E05A 82D88608 F53D7A5C
L:00087A20 58E119CF C1783132 8395C444 CA1B841A
L:00087A30 BD714353 E6360EC3 AE8039B5 4369D140
L:00087A40 65F8BEF1 3A398195 B22963A4 E97E2F6C
L:00087A50 1FFFEC8B 2F601204 4AA2E8D6 C7E7B440
L:00087A60 8EF78925 23245405 A6924520 59D357BF
L:00087A70 9F7E30F4 863271E7 88C8086C B3E29658
L:00087A80 D0004000 00000008 00000008 00006E09
L:00087A90 00000000 00000000 00000000 00000000
L:00087AA0 00088BD8 00000000 00000030 00000030
L:00087AB0 00000003 90065D80 00006BC3 00000003
L:00087AC0 00000030 00006BD3 000000BF 90069200
L:00087AD0 1001C3F5 00080F80 00080F70 00000000
L:00087AE0 00000000 00000000 0008000C 00014B80
L:00087AF0 00080F80 0001795C 00080F80 1001832C
L:00087B00 5149465F 1C5487FC 024B0129 A7A8DBBC
L:00087B10 BDCD5D2F 1205673F B12A3BE7 FA72F35B
L:00087B20 797EF70F 515CAFE8 122C0DBC 00000000
L:00087B30 00080049 00000000 00080049 00087F9C
L:00087B40 FFFF1F07 A0B00E19 FA062A12 D41944D5
L:00087B50 BA6EE8EC D3FE03A6 40579534 FA436BC3
L:00087B60 AABA3EDC 00000000 00015BA0 00000000
L:00087B70 00015BA0 0008002C FFFF1F07 E5FCCC38
L:00087B80 00000000 0105C461 00000EA4 00002916
L:00087B90 98EFFFFF B4B17119 07251D68 B484B94B
L:00087BA0 58969B1D 6D543020 1220E119 9D7F5353
L:00087BB0 FEE77708 843BED1C B4D78072 9913757E
L:00087BC0 BF7C9666 102E1908 519367C7 DE4C82A3
L:00087BD0 5D32DFBE 280D4C81 08808046 0FCEE9BE
L:00087BE0 F7FE2256 97058BC2 58021E3D B64CEFAA
L:00087BF0 F56CFA9C 1689436A 53911A25 6A2FE884
L:00087C00 5DEBF644 137EC110 8206B1C3 62D1BA32
L:00087C10 33C1F754 C9938B2C F420F512 DE23152A
L:00087C20 5604E2E3 06D41AF1 0411AF5C 610FEFAC
L:00087C30 6FE3914E 945BAA42 089A1480 FA9A21DC
L:00087C40 9B283FE6 E62F72E0 219604B4 7EE78D9C
L:00087C50 DC5F2FB4 78831820 8C1C62CC 3600297F
L:00087C60 51FAFE4D 4AAA999A 292D0034 6DEEF695
L:00087C70 DFAEFF96 1392C400 0268E349 9171B38E
L:00087C80 E96C3F2F D8AD1ABD 4C548889 DA5813EA
L:00087C90 6ACC420A 1A8CD063 5EBF90A2 9C0FE9CC
L:00087CA0 87F3702E 1431E267 1B39878D E7D13BE4
L:00087CB0 76280BE3 01495A27 2A618C82 B4E0CE5E
L:00087CC0 AD687DF9 55626D24 08655354 F459F573
L:00087CD0 4BF24367 07D40418 8614F807 4C5262C2
L:00087CE0 A3B54EBE 45380242 7A2B5A08 6E5C9B57
L:00087CF0 FBB9DCB5 80040640 0F136E09 CC17B0FD
L:00087D00 5152495F E0300114 02076ABA F0416CDD
L:00087D10 C7FCEFA6 6DC25BE0 09416033 B7AF07BD
L:00087D20 92AE3C3E D47A0B8E 55BF1408 FDBEB9FE
L:00087D30 7CDFFAFF 048606BB 8008051C DE3DCFE0
L:00087D40 FDABF1BD E5C1383E 0C6E83B2 458A1E6B
L:00087D50 AA8F7F7F A14D89E1 DE0C1199 C7E4ABF6
L:00087D60 7DDDD7AD 28A41817 191A4F05 D70F6A77
L:00087D70 0D7FFF2D 0B04AD11 800B8611 FB2A8F3B
L:00087D80 87DB6DDB 84BF7AF1 04CB6545 9ED74EC7
L:00087D90 2FE6976F D2CD1108 80435DDA 913F8D35
L:00087DA0 3AFD86B7 3406C451 D4F638FA 5F464A4D
L:00087DB0 9CB929FA 42140480 09728DD4 1D12DBD0
L:00087DC0 A49CDCBB 4F2949D5 41015281 7611D216
L:00087DD0 4069BD69 E0E18191 74589259 DF68BB9F
L:00087DE0 EF9FFD7C 715C31B7 20000192 00001BDF
L:00087DF0 00000E42 D000A000 00000E42 D000A000
L:00087E00 40000192 00000000 00000000 00000000
L:00087E10 00002A04 00000000 00000001 00000000
L:00087E20 00000000 00000000 00000000 00000000
L:00087E30 0000000F 00000000 1001CBA5 00000000
L:00087E40 00000000 1001C172 00087E80 1001C173
L:00087E50 00087E80 1001C173 1001CC81 00000010
L:00087E60 1001BE37 0000004C D000A620 00000000
L:00087E70 0000004C 00000003 1001BE6B 00000061
L:00087E80 1001BEC7 00000003 00087E40 00087D00
L:00087E90 00087F80 00087170 10025440 0000A19F
L:00087EA0 00016298 830858E0 0000A89B 000812E8
L:00087EB0 1002366F 000812D8 00081254 00000000
L:00087EC0 00000190 00000067 00000066 00000000
L:00087ED0 00000000 000812E8 1002366F 000812D8
L:00087EE0 00081254 00000000 000812D8 00087728
L:00087EF0 00000000 00004A99 2000013F 1005513C
L:00087F00 4356535F 9FDACFAF 2A33B2C1 900003C0
L:00087F10 00087F7C 10018000 0000000B 00016494
L:00087F20 00087F7C 00000000 A0600000 00015D20
L:00087F30 00087F7C 90000000 908817FF 00087F7C
L:00087F40 D000A820 00000002 D000A000 00085F68
L:00087F50 00087F7C D000A820 00000002 0001624C
L:00087F60 00000003 00000000 000000FE 00000001
L:00087F70 00080000 00014E4C FFFF1F49 00000000
L:00087F80 00000000 90000000 00000BD8 00014E85
L:00087F90 00014E95 00014EA9 00014EBD 000154B3
L:00087FA0 0001542D 0001538B 0001503F 00000002
L:00087FB0 00014D00 00000003 00000000 FFFF0474
L:00087FC0 00000002 0000002A FFFF23AD D000A000
L:00087FD0 00014D00 FFFF353A 00001515 00000000
L:00087FE0 00000000 00000002 0000003D 00000005
L:00087FF0 FFFF064D 0000030C 00000000 7F1D4D34
Cur_SP=00087E9C
FIQ_SP=00087D00,830858E0
IRQ_SP=00087E40,0000A89B
SVC_SP=00087F80,00016298
SYS_SP=00087170,0000A19F
*** HALT ***
Filipp_TS
Re: ST1000LM024 BSY
Postby Filipp_TS » 29.05.20, 10:10
Try to send LE terminal command.
Also try to get access by Terminal mode (When you launch utility and select family - check is it possible to mark Terminal mode for init).
marcuscercal
Re: ST1000LM024 BSY
Postby marcuscercal » 16.07.20, 19:42
Hello guys,
Fiilipp, We have the same issue here w/ LM025. The terminal log is almost the same. Some times, we have the eng> access after the HALT, i sent the LE command, but the log comes again ( without RST or PWR off/on ). Beside that , i have the DBG> access too. Wich is the procedure for DR ?
The terminal init dosen't works in this case.
Thanks in advance.
Regards.
Marcus
marcuscercal
Re: ST1000LM024 BSY
Postby marcuscercal » 22.07.20, 20:10
Case updated :
After the HS procedure , i can gain the SA .I'm founding some modules issues, i will try fix it and post the results.
Regards.
Marcus
Filipp_TS
Re: ST1000LM024 BSY
Postby Filipp_TS » 24.08.20, 12:02
As soon as you get ready state try to reduce number of ReadRetry (it makes in RAM):
https://i.imgur.com/1K7z8Y4.jpg
Then check Sa modules condition, fix damaged of them if necessary
Return to “Spin Point”
