I have this Samsung that is always busy.
It spins OK, no clicks, no spin down.
I get this terminal:
SpnOk
DAC:-00410
H: +00000
SK C: 0000CC03
ENG>SRV>
SvoTbl Loaded
BD
ENG>LE
E:0001 - Inv Cmd
ENG>
I don't have a donor compatible here right now, so hot-swap is not possible for now.
Any other things I could do?
Samsung SP1203N Busy
Moderator: Garry_TS
Re: Samsung SP1203N Busy
Case solved and closed.
pclab wrote:Source of the post Case solved and closed.
Pclab ,
What Was The Issue ?How did You Solve This
Bad PCB. Swapped for another.
